Hot collet and router bit - Router Forums
 6Likes
post #1 of 16 (permalink) Old 07-02-2020, 01:18 PM Thread Starter
Default Hot collet and router bit
I have just replaced a Bosch Colt with a new larger 1.25 hp Bosch GKF125CE on my CNC machine. After an approximate 10 minute run with the new router, the collet and bit were very hot. Too hot to touch for about 2 minutes. I never had this issue with the Colt. Is this a sign of future problems to come, does the router need some run time to "loosen up" or should I stop using it??
twyns is offline
post #2 of 16 (permalink) Old 07-02-2020, 02:02 PM
difalkner's Avatar
First Name: David
Welcome to the forum! Add your first name to your profile to clear the N/a in the side panel and so we'll know what to call you.
We do like photos so show us your shop, tools, projects, etc. whenever you're ready. What sort of woodworking are you planning or doing with your CNC?
First question would be what are your feeds/speeds/depth of cut? Heat is a good indicator you're going too slow. Our CNC has a 3kW water cooled spindle and I cut fairly aggressively. After 10 minutes of what I would call heavy cutting the chips are very warm and so is the work piece near the cut, but the bit and collet can easily be touched as soon as the cut is over and the bit stops spinning.
David
David
Curly Wood Shop on Etsy
Romans 3:23
difalkner is online now
post #3 of 16 (permalink) Old 07-02-2020, 02:23 PM Thread Starter
Hi David, thanks for the reply. I'll be very honest with you. I've been making these same items for 5 years and have always went with the data computed at setup. I've never changed any settings other than pass depths and stepovers. Never had a problem. That is what stopped me today, when I went to change to a different bit and felt the extreme heat.
difalkner likes this.
twyns is offline
post #4 of 16 (permalink) Old 07-02-2020, 03:05 PM
difalkner's Avatar
First Name: David
Got any photos of your setup, Tom? What are your feeds/speeds and in what material are you cutting?
David
David
Romans 3:23
post #5 of 16 (permalink) Old 07-02-2020, 03:35 PM
The only things I can think of that would cause the problem are some slippage between the bit and collet (any signs of that on the bit shank?), a dull bit, too slow a feed like David said, or a bad bearing on the router (but you should be able to hear that). If it's the bottom bearing then running it for several minutes without doing any routing should still cause it to get hot.
post #6 of 16 (permalink) Old 07-03-2020, 07:22 AM
sreilly's Avatar
First Name: Steve
I was going to suggest checking/changing the bit but Charles has that covered. If you're concerned it might be the router, which I doubt but could be checked, the motor would likely be heating up and that could be checked by checking the amp draw while running under a load. Best guess is the bit but it's a guess.
sreilly is offline
post #7 of 16 (permalink) Old 07-03-2020, 01:35 PM
roxanne562001's Avatar
First Name: Roxanne
roxanne562001 is online now
post #8 of 16 (permalink) Old 07-03-2020, 04:44 PM
Welcome to the forum. Does the motor get hot too, or just the bit?
Herb Stoops is online now
post #9 of 16 (permalink) Old 07-03-2020, 06:27 PM
you running the bit in reverse...
post #10 of 16 (permalink) Old 07-03-2020, 06:58 PM
How do you do that? I wanna try that! Do you plug it in upside down?
HErb
