Looking for input on project (Garden Door) - Router Forums
 17Likes
post #1 of 13 (permalink) Old 07-10-2020, 10:37 PM Thread Starter
First Name: Robert
Default Looking for input on project (Garden Door)
Hello to all;
After building two arbors (with arches on top) for the wife she has moved on to a garden gate project. This gate will actually sit under the most recent arbor/arch I built. I have built gates before, even monster sized gates that have never sagged because I overbuilt them. Mostly some kind of 2 x 4 & Z type frame.
The current project will be similar to the attached picture and I am concerned about how to get this into a "sag proof" design based on the picture of what she wants in the end. I will probably make the gate out of Western Red Cedar but open to suggestions. It will be a big gate, roughly 7 foot to the top of arch, and 40" wide (more or less)
As far as the "top part", the circle area, I wonder if I can get away with routing this out of some kind of plywood for simplicity and protecting it from the elements with a couple layers of exterior paint/stain?? I could always make this out of WRC using a segment calculator, but my past arches have required a 2 x 6 board to obtain a 3.5" width and this appears wider than 3.5" - Based on: Woodturners Resource Segment Calculator
As far as frame joinery, open to suggestions, based upon simplicity but requiring strength.
Any comments about approach, design, materials, etc would be greatly appreciated.
Robert
honesttjohn likes this.
ABear is offline
post #2 of 13 (permalink) Old 07-11-2020, 12:32 PM
First Name: Gary
Robert, If you are looking for a 3-1/2" thickness ring, you can use a 6" nominal board which actual measurement is 5-1/2".
MEBCWD, Gaffboat and Herb Stoops like this.
Woodworking is like wetting myself...Only I know that warm feeling!
gmercer_48083 is offline
post #3 of 13 (permalink) Old 07-11-2020, 01:21 PM
Bstrom's Avatar
First Name: Brian
Plywood would give you some flexibility to join the circular portion to the bottom via some sandwiching, etc. but I do wonder how it will weather over time. Perhaps some banding to seal off the edges? Very pretty door, BTW...
Common Man Woodworking
Powell, TN
Bstrom is offline
post #4 of 13 (permalink) Old 07-11-2020, 01:43 PM
Gaffboat's Avatar
First Name: Oliver
Since the door is painted, the majority of it could be made from plywood which would prevent it from sagging, and an epoxy coating would seal the wood and make it weather-proof. Many of today's boat designs use epoxy coated plywood. The appearance of the separate vertical wood slats could be created by simply routing a groove in the face of the plywood. Alternatively, a plywood core sandwiched on both faces with solid wood might accomplish the same thing.
MEBCWD, Nickp, Herb Stoops and 1 others like this.
Gaffboat is offline
post #5 of 13 (permalink) Old 07-11-2020, 02:03 PM
The way I would do it would be to glue 2x6's together all the way across with splines and waterproof glue.(like a solid door)Then with a router and a "V" bit route the inside/outside circle and vertical board pattern both sides, just like the picture, take a saber saw and cut out the hole. Also use the router to cleanup the edges of the hole. I don't think there is any worry here about sagging.
Something like that.
HErb
Nickp and dman2 like this.
Herb Stoops is online now
post #6 of 13 (permalink) Old 07-11-2020, 05:53 PM Thread Starter
First Name: Robert
Thanks to all for the comments.
Some of the ideas I had thought of and some I had not thought of so I really appreciate all the input.
Since this is going to be a garden gate, the wife may want a rough wood look and I may just use cedar fence boards, undecided.
Any other comments are welcome.
dman2 likes this.
ABear is offline
post #7 of 13 (permalink) Old 07-11-2020, 07:48 PM
Bstrom's Avatar
First Name: Brian
I like the rough wood look As long as it’s sophisticated! I have a bunch of rough sawn pine to work with and never tire of it.
Cedar would be a good choice but I wouldn’t want it to gray out. Paint would be my preferred choice for color/contrast in the setting you have to put it in. Let us know what you settle on, so we can do it too!
Powell, TN
Bstrom is offline
post #8 of 13 (permalink) Old 07-12-2020, 10:32 AM
Chris Itin's Avatar
First Name: Chris
I really like the idea of sandwiching 1x rough cedar on both sides of 3/4" exterior plywood. The plywood gives needed stability to circumvent sagging, and you can get 1X cedar wider than 6" so the circle segments can be wider than 3.5". You could even recess the plywood around the whole sandwich so that cedar banding could be added to hide the plywood edges. A good epoxy like boatbuilders use would provide a weatherproof finish while keeping the rough appearance, if desired. I would guess that some sort of surface hinges like are used on a lot of gates would be needed. I don't think traditional mortised hinges like used on most doors would work with this type of construction.
DesertRatTom, Nickp and dman2 like this.
Getting old ain't for sissies.
Chris Itin is offline
post #9 of 13 (permalink) Old 07-12-2020, 01:54 PM Thread Starter
First Name: Robert
Thanks to all for the latest comments. I have been playing around with some scrap wood and the wife seems to like this design which is still under consideration. She likes using a rough sawn looking 5-1/2" width board with a half inch or so in between for an informal look.
The sides would be 3-1/2" trim that would go to the top and meet the circle (not shown in the mock up).
I like the idea of a cross trim board on the upper half, wife says no go.
Back to thinking of ACX Plywood for the circle with some additional protection via paint/stain/sealant. I might use a slightly thicker plywood (like 3/4") and use 5/8" thick trim so I would have a slight raised appearance were the trim meets the circle.
Two plywood circles with pickets sandwiched in between. Trim also on both sides.
Pictures give a rough idea.
ABear is offline
post #10 of 13 (permalink) Old 07-12-2020, 01:55 PM Thread Starter
First Name: Robert
Pictures did not attach, trying again.
The one picture is shown to be clear about the raised edge look intended.
Name:	Capture Mock 001.JPG
Nickp likes this.
ABear is offline
