jamb nut use - Router Forums
post #1 of 8 (permalink) Old 07-27-2020, 02:46 PM Thread Starter
Default jamb nut use
Craftsman commerical router 315.17080
do you tignten the lock nut against the collet nut or the lock nut
I have not used it in years and the owners manual does not cover this
Tom Olson is offline
post #2 of 8 (permalink) Old 07-27-2020, 05:00 PM
Tom; can you post a photo?
Normally of course the jamb nut would tighten against the component that's at risk of loosening/moving. Are you saying that the armature or shaft has an adjustment as well?
(Sorry, I can't picture what you're describing. )
Oh! Welcome, by the way!!
DaninVan is offline
post #3 of 8 (permalink) Old 07-27-2020, 07:28 PM
Welcome to the forum, sorry to hear you are having trouble with your router. I can not visulize your problem, Save a picture to your desktop, then drag it into the space at the bottom that says "Drag and Drop file"
Most routers have a nut on the shaft that you can hold the shaft, with a wrench from turning while you loosen/tighten the collet nut.
Herb Stoops is offline
post #4 of 8 (permalink) Old 07-27-2020, 08:48 PM
Hi Tom and welcome. Without a photo I would be inclined to say the jam nut should go up against the bottom bearing or that part of the housing.
post #5 of 8 (permalink) Old 07-27-2020, 11:00 PM
old55's Avatar
First Name: Ross
Welcome to the forum Tom.
Ross,
old55 is offline
post #6 of 8 (permalink) Old 07-28-2020, 07:35 AM
sreilly's Avatar
First Name: Steve
Welcome aboard Tom.
sreilly is offline
post #7 of 8 (permalink) Old 07-28-2020, 08:46 AM
CharleyL's Avatar
First Name: Charley
If you mean the nut that holds the collet in the end of the router shaft to lock the bit in place, most routers today have collets with a groove around the outside that the collet nut is supposed to snap into and make an assembly. Then, when loosening the collet nut you need to loosen it about one turn further and this will pull the collet out of the router shaft, loosening the bit for easy removal and change. If you don't snap the collet into the nut before use, you cmay have considerable difficulty removing the bit after use, since the outside of the collet is tapered and will nest tightly into the tapered hole in the inside of the router shaft. Getting the router bit out after use is much easier with the collet and nut snapped together before use, so the nut will hold the collet and bit tightly in use, but also help to pull the collet out of the router shaft when removal / changing of the router bit is desired.
I have no experience with your model router, but most routers made since about 1960 work this way.
Charley
Central North Carolina
CharleyL is offline
post #8 of 8 (permalink) Old 07-28-2020, 11:33 AM
MEBCWD's Avatar
Welcome to the Router Forums Tom. That model number returns a not found message, is it the right number?
MEBCWD is offline
