a bad day with a Porter Cable 3 1/4 horse router - Page 6 - Router Forums
 66Likes
post #51 of 53 (permalink) Old 08-27-2020, 07:39 PM
Originally Posted by srjaynes49 View Post
Count count on Thursday’s... I have FOUR high amperage routers. HP ratings are for marketing departments! It’s wattage divided by 745. Anything else is pure hokem. 3.5 HP would be over 2600 watts or nearly 22 amps at 120. Volts. Try that on your 15 amp circuit breaks kiddies!
have a read..
Stick486 is offline
post #52 of 53 (permalink) Old 08-27-2020, 08:03 PM
RainMan 2.0's Avatar
Hey all , I found a buyer for my 75182’s . His only concern was that they had to be Type 3 .
I didn’t know this till I checked mine , and they are both Type 3 .
Is that a good thing ?
Ok ,I never insulate
RainMan 2.0 is online now
post #53 of 53 (permalink) Old 10-21-2020, 08:11 PM
First Name: art
Originally Posted by Charlie68 View Post
I need to hear from someone who has purchased a 3 ¼ horse Porter Cable router motor since the first of the year. I am looking at that time period because I know in the past Porter Cable made a good product.
I ordered mine May 5th and got it 2 weeks later. I built a router table for it and got the unit in service 1st part of June. I noticed the bits were hot when I removed them from the unit. To test the motor, I let the router sit overnight. Next morning I ran the router with no load/ no bit for 3 minutes. The collect was so hot I could not hold my fingers against it.
Porter Cable does not publish a phone number on their web site I had to do the email form. A week later their customer rep sent me a link to start the warranty repair process.
My nearest repair center is Denver so I shipped the unit there 7-13-20. Per UPS tracking the unit arrived at the repair center 7-14-20.
I received the unit back today 8-19-20 with the same over heating issue. According to the service order enclosed with the router, they had changed just about every part of it. I called the Denver repair center and was told that “we changed almost all of the parts TWICE. Please send the unit back and we will try to exchange or replace it.”
I asked if it was going take another month to get a different unit and was told to be sure to enclose the service order. The repair tech said
hopefully that will help speed up the process.
To say I am upset does not even come close.
The point of my question: Am I just under a bad cloud or have others had this hot collect problem?
Also if you are looking to buy one of these routers, test the unit as soon as you get it.
It could be that that large router is not intended to be mounted upside down on a table. I had a lot of bearing trouble with table mounted routers, years ago. these were smaller units with no variable speed control.
We always had at couple of 3-1/4 hp PCs in the shop. We used them for all the cutting of 1.125 inch particle board used in counter tops etc. We would screw the router to a board of the right length for the radius of a curve then just pivot around a screw or dowel drilled into our wood floor.
We once did an Oak communion rail with a 30 foot radius. In my commercial shop we would use the router to make curved ribs for furniture parts that were wrapped with bendable plywood, such as 3 ply Luan or 1/8 bending Birch. We could then laminate or cover with flexable veneer. Picture quality is not good because I re photographed old 35mm prints.
RainMan 2.0 and Charlie68 like this.
Art S www.schmitt32.com
Drilling for cabinet construction and hardware installation
schmitt32linedrill is offline
Currently Active Users Viewing This Thread: 12 (0 members and 12 guests)
