Metal cutting end mills for routing wood - Router Forums
 12Likes
post #1 of 14 (permalink) Old 08-27-2020, 08:35 AM Thread Starter
Default Metal cutting end mills for routing wood
I have a milling machine for metal working and have a number of spiral cutting end mills. Has anyone used them for routing box joints or other straight slot cuts? I am not sure they are solid carbide but would expect they are. Any information would be appreciated. Thanks Larry
lalkie is offline
post #2 of 14 (permalink) Old 08-27-2020, 09:58 AM
JOAT's Avatar
First Name: Theo
I've read about it being done. Also read about using metal lathes for turning wood. I wouldn't ask, I'd just try it, and see if I liked it.
JOAT is online now
post #3 of 14 (permalink) Old 08-27-2020, 11:11 AM
CharleyL's Avatar
First Name: Charley
I've done it, but I found that I often get better results using router bits. Metal responds to different blade cutting angles than wood. Try it for yourself, but don't invest a lot of money until you get the results that you want.
Charley
TWheels likes this.
Central North Carolina
CharleyL is offline
post #4 of 14 (permalink) Old 08-27-2020, 11:27 AM
i believe that i have read that end mills are typically up-cut bits. i am thinking you will get better results with down cutting for the tasks you mentioned. wrt metal working bits, i'd bet that the cutter geometry is different than that for wood, as well as efficient/recommended rpm's.
TimPa is offline
post #5 of 14 (permalink) Old 08-27-2020, 12:00 PM
The geometry for router bits meant to cut plastic are also different from ones for wood. Like Charley said, different materials react differently to the cutter.
TWheels, CharleyL and Stick486 like this.
post #6 of 14 (permalink) Old 08-27-2020, 01:37 PM
MEBCWD's Avatar
I do know one person that uses 4 flute bits, made for metal cutting, 90% of the time for his wood projects. I don't recommend it for the hobby level machines because most of them are limited in feed rates needed to get the proper feeds for a 4 flute bit.
Another important thing to remember is that the chips created when the bit is cutting carries away the heat produced while cutting. Moving too slow because you are trying to make the bit meet optimum feed rates and spindle speeds for a 4 flute bit will often lead to burning material and overheating the bit. This could also be hard on your spindle because they are normally limited on their lowest speed recommendations.
Of course, that is just my opinion.
TWheels and roxanne562001 like this.
MEBCWD is offline
post #7 of 14 (permalink) Old 08-27-2020, 03:42 PM
Good point Mike. The gullets on metal cutting bits are shallower for the added strength that gives the cutting edges but it doesn't allow for getting rid of wood chips at the higher feed rates of cutting wood.
post #8 of 14 (permalink) Old 08-27-2020, 05:25 PM
MikeSibley's Avatar
Hey, when I look at websites, how do I know if a bit is made for metal, wood or plastic? Will a end mill made for wood cut plastic? I have an Avid machine on order and this is all new to me. I want to cut the dust shoe out of HDPE as per the video on their website. I have begun to look at the bits and actually ordered a couple. Not trying to hijack the topic but I hope I am not purchasing the wrong things.
“Those who would give up essential liberty to purchase a little temporary safety, deserve neither liberty nor safety.” – Benjamin Franklin.
MikeSibley is offline
post #9 of 14 (permalink) Old 08-27-2020, 06:18 PM
go to the bit's manufacturer's site...
plug in your particulars they will tell you what bits you need...
Stick486 is offline
post #10 of 14 (permalink) Old 08-27-2020, 07:34 PM
MikeSibley's Avatar
Thank you sir!
