Router plate as base plate?? - Router Forums
post #1 of 7 (permalink) Old 05-23-2009, 12:44 AM Thread Starter
xplorx4's Avatar
First Name: Jerry
Default Router plate as base plate??
I have never heard of anyone doing this before so before I do anymore and learn a hard lesson give some advice.
I needed to clean up the edges of my counter tops so I can add oak to them; I just needed to take off just a 1/8" or 3/16". I got the router out and was going to put on the plunge base when I decided to try it with the router table plate attached instead. It worked great; in fact I had better control of the router than with the plate that comes with it on the plunge base. This was especially true at the beginning and the end of the top. I did the three sides that needed doing. I think if one had to do inside corners it probably would not work, but outside corners it might. At any rate just a thought.
So please tell me what I may not be considering that would be detrimental to me the router or top. I know this would be more difficult in some applications, but for just doing a strait cut seems to work OK.
(The power cord is tight so as to hold the router in place while I took the pic)
Lamentations 3:22-23
xplorx4 is offline
post #2 of 7 (permalink) Old 05-23-2009, 12:52 AM
curiousgeorge's Avatar
First Name: George
Correct me if I am wrong, but I think Bj uses a 9" x ?" base plate all the time.
George
Fort Worth, Texas
City where the west begins.
curiousgeorge is offline
post #3 of 7 (permalink) Old 05-23-2009, 01:28 AM Thread Starter
xplorx4's Avatar
First Name: Jerry
I don't know I have just never heard of someone doing it/
xplorx4 is offline
post #4 of 7 (permalink) Old 05-23-2009, 07:09 AM
levon's Avatar
First Name: levon
i had heard one of the reasons to use an insert plate in a table originally was to be able to take it out and use it out of the table. that is also why it is not screwed down. cant remember where i saw this.
levon
levon is offline
post #5 of 7 (permalink) Old 05-23-2009, 07:22 AM
Bob N's Avatar
First Name: Bob
Hi Jerry,
Bob and rick do it on their shows
Bob N is offline
post #6 of 7 (permalink) Old 05-23-2009, 09:38 AM
Ghidrah's Avatar
First Name: Ronald
While I was still using the PC plunge in my RT I used the RT plate out of lazy a bunch of times.
Ghidrah is offline
post #7 of 7 (permalink) Old 05-24-2009, 06:19 PM
First Name: Ken
Send a message via MSN to Kenman101
It should work fine, it really does not matter if you are using the insert or your base plate, they both are the same. I would not go to all the trouble of unscrewing it from your insert.
Kenman101 is offline
Triton Router Base Plate garbo.hunter Triton 10 08-09-2013 09:00 AM
Model 320.17542 and table routing 46_trap Table-mounted Routing 44 10-16-2011 01:40 PM
Moving Sub Base to Another Router don1 Portable Routing 8 01-25-2010 09:47 AM
Router Base Plate Question dabeeler Table-mounted Routing 3 12-24-2008 01:21 PM
