I am trying to route (dado) MDF to support other MDF shelfs. The MDF seems to measure 3/4 inch and the router bit is 3/4 inch, but the pieces don't seem to fit.
Sometimes the MDF is actually 'bigger' than 3/4 inches on the edges if it has had a chance to absorb moisture, or has been manhandled. I have learned real quick not to force it into the dado, you can end up making scrap real fast.
Try using a sanding block to chamfer the edges of your shelves just a bit and see if that doesn't help get it started into the dado.
The other culprit could be your 3/4 inch bit is not exactly 3/4 inch. In that case, you can either offset your guide by the tiniest fraction and widen the groove just a bit, or make a rabbet on your shelves so that they fit into your dados.
Like I mentioned earlier, If you force a shelf that is too tight into a dado in MDF, you'll probably cause the side to split, or to curve outward.
Hey Jefa - That is so weird that you wrote about the mdf and the dado. That is exactly what I was doing yesterday afternoon and mine didn't fit either. Plus, mdf is really messy. Tons of dust. It cuts easily, but don't know if it is worth it with all the dust. I decided that by the time you clamp everything and line it up perfect, it would be much easier to do the dados on the table saw using the "dubby" crosscut sled. I'm on my way now to replace the mdf with birch plywood. Have a great day and happy woodworking.
Yes. And the dust can be toxic. So can the gas produced when it is cut with a power tool, particularly when there is a little heat buildup. To add to that, in recent years, MDF has been supplied from countries with lax or nonexistent safety laws regarding toxic ingredients. Even a standard dust mask is not enough protection. I would not cut, sand or rout MDF in a basement, for fear of the safety of the occupants, no matter how good the DC system. The outgassing of formaldehyde and who knows what else is just too risky for my family.
I'm on my way now to replace the MDF with birch plywood.
Demi
Yes. Way more satisfying to work with, stronger, takes a good finish and does not swell with moisture.
However, the glues in it can also be toxic, with large amounts of formaldehyde and who knows what else. There is a big stink (literally) with Chinese plywood in trailers right now. Again, countries with lax or nonexistent laws are poisoning us.
Even our own country needs to be watched. A coupla years ago, the EPA attempted to exempt US plywood producers from toxic air pollution limits. They ere overruled by the courts, but that ruling only addressed plywood production, not the inherent toxicity of the product itself.
You can Google MDF toxic or Plywood toxic for a lot of info on this.
Hi Jefa
I'm in the same situation, when I measured the thickness (calipers) , I got various readings on the same sheet from pieces I've cut. MDF is not a stable wood (moisture speaking).
I'm building a "changing table" for my daughter (expecting 1st child).
She wants it painted so I'm not going to use good wood. This is my first time building a whole project with MDF. (Tried some pocket screws & well, don't snug them very tight . (learning curve here)
I'm tempted to drill out where the screws go, glue in a 1/2" plug & hope that holds better.
The tip about sanding the edges is what I used to get the dados to fit.
Plan to take care & use lots of glue & clamps.
Routs good but I here it's tough on bits.
Here's a question?? At Lowes, 1/2 MDF is $4 more per sheet than 3/4. What gives?
Related Threads
747K posts
128.1K members
Since 2004
