Hello N/A You may want to check the router reference on the jump menu and select the freud section there. Also the router raiser shows the 4 bolt mount. You can make your own if you so desire,(This is not hard to do) Or you should be able to order it from the table manufacturer If you do make one, Make sure that the hole marks are perfect, and the center hole especially must be perfect. It is uses with the bushings or collar
which rub the template. So any difference is magnified when the router is turned
Related Threads
747K posts
128.1K members
Since 2004
