Exploding Router! - Router Forums
post #1 of 5 (permalink) Old 10-02-2005, 10:39 PM Thread Starter
Default Exploding Router!
Just thought everyone would like to see this. This Crasftsman router was mounted in my table. It blew out the bottom of the motor casing that holds the bottom bearing. I didn't get hurt but I did have to change my underwear after it happened! Just goes to show that's it's a good idea to give your power tools a good once over every now & then!
Dominick Giarraputo is offline
post #2 of 5 (permalink) Old 10-03-2005, 12:00 AM
Visteonguy's Avatar
First Name: Terry
Geesch,, Dominick...... Glad you were not hurt,,,,,some how I am not surprised it was a Craftsman router,,, Guess its time to do some shoppin,,,
Terry
It seems like every where I go,,,,,,,,,,,,,,,,,,,,,,,,, there I am...
Visteonguy is offline
post #3 of 5 (permalink) Old 10-03-2005, 08:14 AM
kp91's Avatar
First Name: Doug
I guess sparks and sawdust don't mix...
A little shot with the canned air (the kind for computer keyboards) works well at blowing the sawdust out.
1 John 1:9
Fredericksburg, VA
kp91 is offline
post #4 of 5 (permalink) Old 10-03-2005, 05:07 PM
Glenmore's Avatar
First Name: Glenmore
Wow that's a new on me. Glad to see you didn't get hurt. First time I've ever seen or heard of that happening. Did it give you any warning sounds when it blew? Probably cased by to much pressure on the colect more pressure on it from using it in a table then using it free hand. I had that model I actually threw it out. Had problems with the adjustment. Took it to sears and was told it would cost more for them to fix then to buy a new one. Went to Porter cable from then on.
Glenmore
Mountain Top PA
Glenmore is offline
post #5 of 5 (permalink) Old 10-03-2005, 07:09 PM Thread Starter
No warning signs or sounds at all. I thought maybe the lower bearing had locked up but it was just fine. Luckily I was hollowing out a block of stock for a box so the bit was covered when it happened. I never thought that I had ever overloaded it but I guess it only takes once to cause stress cracks that you might not see.
Mixing Bosch 1617 Router fixed base with Craftsman professional router sf_basilix Starting Off 17 10-11-2012 05:20 PM
