What causes wood burning when routing ? Does the power of the router have a direct effect on the outcome ? What about the rate or speed of feeding the wood ? any comments on this subject :thank_you2:
Feeding too slow will cause burning. But it's not the only factor. Not all router bits are created equal. Freud, Forrest, Amana etc. charge a lot more than Harbor freight for a reason. Also the bit should be used near it's recommended RPM.
You using your router on a table or hand held? I try to use the table when ever possible, so much easier to control all these factors. One more thing, don't take the whole profile at once. I like making a light finish cut, .010 or less. with a good bit and fast feed rate, it will leave a finish that don't even need sanding!
Harry
the TX one
All router bits are made to cut the profile in one pass the norm even the Big bits ( panel bits) but the router has a voice and many things come it to play when you route the profile , how hard the wood is,how soft the wood is, it comes back to the voice thing, it's like when you are drilling a hole you can hear the drill motor telling what it wants, it's the same with a router speed of the bit and the rate of feed all come into play, no hard rule it's a practice/learning thing that you get every time you use the router..
Until you get it down use the 2 cut way to clean up the burn marks, it's hard to not put them in place, I do it from time to time if I stop too long in a corner, the bit gets hot and burns the stock
Like I said no hard rule it helps to let the bit cool down after each pass...
Adding to the experts comments (above) here's the observations of someone who's still got a lot to learn about routing. I found that I was moving the router far too timidly and run it too slowly when I first started using it. With a sharp bit spinning up at the bit's ideal speed it melts through even hard maple like butter.
Obviously you must listen to the router and not overload it but I haven't had that problem. When I press myself to move the router faster (don't mistake that with "pushing the router against the wood faster than it can cut") and run it up at speed I get really nice cuts.
The coasters I recently made were tough to do without burn marks. Using a plunge router and a dish cutter to make the recesses, I tried to keep the router moving as I plunged and unplunged(?). But I still had burns at my start and stop points that needed quite a bit of sanding. The bit was from MLCS, I will probably replace it eventually with a Whiteside. A see if it makes a difference.
Related Threads
747K posts
128.1K members
Since 2004
