Hi Everyone,
I need to install aproximately 50 4X8 sheets of plywood slat wall that will be stain grade. I need a one step router bit that will cut the slotand leave enough room for metal inserts that reinforce the slots.
These 4x8 sheets will be installed horizontally . Do I use a ship lap joint to make the fit up tight. My slats will need to be 3" oc.
Thank You,
Inletjoe
Thank You,
Inletjoe
