Very Rookie Question - Router Forums
post #1 of 9 (permalink) Old 11-12-2005, 04:10 PM Thread Starter
Default Very Rookie Question
Hi Everyone,
I'm new to the forum and very excited I found it. I have probably less than basic routing experience. I have used one a few times a few years ago in school. I am slowly learning on my own and buying used equipment to expand my basement workshop.
I have a craftsman 1/2 HP router. The problem is I set my first bit and practicied some cuts but now I am very confussed how to remove the bit? I bought the router used and the person I bought it from told me he lost the wrench used to loosen the piece thath olds the bit, I attempted ot use an adjustable wrench to get it loose, but no luck. Can anyone help out a rookie?
I'm sorry for the stupid question.
Schu4598 is offline
post #2 of 9 (permalink) Old 11-13-2005, 11:54 AM
Glenmore's Avatar
First Name: Glenmore
Welcome to the forums. First you should call sears for a wrench. But in the mean time I would carefully use a small pair of channel locks to loosen the nut. To bad if it didn't happen last week or earlier I just threw my craftman router wrench out sorry to say.
Glenmore
Mountain Top PA
Glenmore is offline
post #3 of 9 (permalink) Old 11-13-2005, 12:44 PM
reible's Avatar
Originally Posted by Schu4598
Hi Everyone,
Hi,
You did not mention which router but a lot of the Sears ones have a spindle lock that you engage then use a wrench to loosen the chuck..... is this the issue you are having or ???
Ed
reible is offline
post #4 of 9 (permalink) Old 11-13-2005, 04:02 PM
Hickory's Avatar
You either have a spindel lock on the shaft or you need 2 wrenches
Hickory is offline
post #5 of 9 (permalink) Old 11-13-2005, 04:11 PM
kp91's Avatar
First Name: Doug
How did you secure the bit in the first place? Please post the model number of your router and maybe we can figure out just what you need.
Hang in there, we'll figure it out
1 John 1:9
Fredericksburg, VA
kp91 is online now
post #6 of 9 (permalink) Old 11-14-2005, 11:35 PM
I may have a wrench I can send to you.
Advise your address to me via private message ... hit my name to access.
Routerbit is offline
post #7 of 9 (permalink) Old 11-14-2005, 11:52 PM
fibertech's Avatar
First Name: Derek
Send a message via AIM to fibertech
I have a Craftsman and it has a push in lock to stop the rotation of the bit and collet. My 9/16" open end wrench in handier to me. I hope this helps. -Derek
fibertech is offline
post #8 of 9 (permalink) Old 11-15-2005, 06:05 AM
First Name: Richard
Hi: I would depress the spindle lock, and use an open end wrench to loosen the collet holding the bit. The use of channel locks, pliers etc, may strip the collet nut.
You can call Sears parts depot and give them the model number and serial number and they will sell you the proper wrench/wrenches. They can also supply a copy of the parts and operators manual, for a nominal sum. Hope this helps.. Woodnut65
Woodnut65 is offline
post #9 of 9 (permalink) Old 11-15-2005, 08:42 AM Thread Starter
Thanks for al lthe responses everyone. Over the weekend I figured it out, I'm a complete fool. The router had a lock on it to stop the spindle. I got it going great and had plenty of practice.
Thanks for the help again, I'll be on the forum alot more looking for some advice.
Schu4598 is offline
craftman router question tsbrewers Table-mounted Routing 10 07-22-2010 02:19 AM
Okay, so I do have a question TwoBits Table-mounted Routing 2 12-25-2007 09:12 AM
Craftsman Router Question fibertech Portable Routing 4 05-09-2005 04:49 PM
Question: Sub Base Plate and guide bushings 46_trap General Routing 3 04-17-2005 07:25 PM
