Dummies Difficult Dado's - Router Forums
post #1 of 6 (permalink) Old 11-24-2005, 05:18 AM Thread Starter
Default Dummies Difficult Dado's
Had a real wrestling match with a bunch of dado cuts yesterday and got to thinking ther has to be a better way. Can someone steer me to a square or rectangular base for my PC 890 fixed base? Seems to me a nice straight sideded base would make it a whole lot EASIER to follow a clamped guide than using the standard clear round base.
What I am doing is cutting some 1/4 slots to slip plwood into to create a series of divided sections in a little tool storage chest: 8 slots 2" apart.
Is there a square or rectangular base available that will help or should I try to craft one. I have a sheet of 3/8 stuff.
Thanks.
Birchwood is offline
post #2 of 6 (permalink) Old 11-24-2005, 10:40 AM
First Name: Richard
Hi: I have the Micro Fence guide. It can fit any router, because it's an edge guide but very precise. It has a shoe that goes on the guide that makes repeat cuts very easy. I even did a dentil moulding with it. The down side is that it is pricey..
You could order a square 7" sub base for your router from Oak-Park, that would be less expensive. and use a straight guide with it. Hope this helps ... Woodnut65
Woodnut65 is offline
post #3 of 6 (permalink) Old 11-24-2005, 10:55 AM
Community Founder
Mark's Avatar
First Name: Mark
Do you have a table mounted router? If so then because you want to make the dado cut 2" apart I would cut them like making the box joint.
Increase the distance between the fence and the router bit to 2" instead of 1/4". Cut first dado then put the cut dado over on top of the fence and make the second cut. repeat this operation until you have all of the cuts made.
I would make the sides as one piece, rout the dados in the piece then cut the piece in half to make the two sides.
Mark,
Founder of RouterForums.com
Mark is offline
post #4 of 6 (permalink) Old 11-25-2005, 05:37 AM Thread Starter
Well, I got 'em done, but there has to be a quick and simple way to do this little job.I am going to see if I can purchase a clear base or I will try to make one 7" X 9", bored to take PC collars. Seems to me it it would be much easier to slide down a clamped straight edge. I have a sheet of 3/8 plastic type stuff (the good stuff) I just have to make sure I cut accurately and then figure how to cut hole etc.
Thanks fellas.
post #5 of 6 (permalink) Old 11-25-2005, 11:11 AM
reible's Avatar
Thanks fellas.
Hi,
I'm trying to figure out what sort of problem you were having with the circular base and an edge guide.... Could you go into some details please?
If you want to make your own sub-bases and need a few idea check:
www.routerforums.com/showthread.php?t=395
Where I show how I've done them.
Ed
reible is offline
post #6 of 6 (permalink) Old 11-30-2005, 09:24 AM
Thanks fellas.
To cut the hole just insert the bit you want to use then mount the plate on the router and with it running raise the bit slowly with the micro adjustment through the plate.
garys is offline
Cutting Multiple dado's in a piece of wood kboughton Jigs and Fixtures 14 12-13-2011 09:43 AM
Dados and closet organizer hockeylvr General Routing 6 10-04-2007 11:36 AM
Cross Cutting Dado's On The Router Table... challagan Table-mounted Routing 12 07-12-2007 08:56 PM
Blind Dados on a Router Table High Life Table-mounted Routing 9 01-26-2007 07:06 PM
Cutting dados on a router table paulcomi Table-mounted Routing 6 08-05-2006 10:52 PM
