Uneven dado - Router Forums
post #1 of 2 (permalink) Old 12-18-2009, 03:47 PM Thread Starter
First Name: Larry
Question Uneven dado
I recently wanted a 3/4" wide by 1/2" deep dado. I installed a 3/4" bit in the table-mounted router, positioned the fence where I wanted and ran the piece through. The dado came out fine except the following: The bottom of the cut was about 1/16" higher on both sides than in the middle of the cut. The middle of the cut was 1/2" as desired but the depth on both sides was about 7/16". I think the speed was set at 15k rpm. I had to chisel out the rest to make the dado even at the bottom of the cut.
Any ideas about what went wrong?
fishin&routin is offline
post #2 of 2 (permalink) Old 12-18-2009, 04:16 PM
First Name: Wayne
Larry
There is a few reasons for this. 1- the size of the peice, you didn't mention the size and the bigger the peice the harder it is to apply pressure on the board. The ply could be cupped. 2- did you use feather boards to keep constant downward pressure on the board. My preferred method for this is to use the router hand held with a guide. I will cut rabits and grooves on the table but I use feather boards to keep pressure on the board.
Hope this helps
Wayne
waynoe is offline
Adjustable Dado Jig for Plunge Router diggerop Jigs and Fixtures 3 11-08-2009 02:47 PM
Dado on 2 sides of 3/4 plywood for cubby shelves aquilja4 General Routing 3 11-06-2009 08:17 AM
Adjustable Dado jig - setup problems rovenm Jigs and Fixtures 2 09-21-2009 02:06 PM
Adjusting groove & dado widths. rstermer Portable Routing 22 08-10-2009 04:39 AM
Dado cuts in plywood BK9MJE Tools and Woodworking 4 04-18-2009 01:28 PM
