Trueing a workbench top - Router Forums
post #1 of 14 (permalink) Old 12-26-2009, 10:50 PM Thread Starter
First Name: George
Default Trueing a workbench top
Help!!! I built a workbench and used 2x6 pine for the top...Ole dip-wad didn't pay attention to the grain direction when he glued the edges, you know what happened......I know one can use a 15 inch plane but I don't want to buy one.. Now I have built the skis and am thinking how to use them with the router to level it? And what bit to use? I thought of using a base mounted to the router about 5 inches wide and 15 inches long to act like a bench plane. Is this feasible or are my meds out of control? Thanks for the look see.
Best Regards,
George Cole
" Regulae Stultis Sunt "
George II is offline
post #2 of 14 (permalink) Old 12-29-2009, 08:04 AM
gts
you should be able to screw a piece of angle iron to each long side of the bench. then you can build a sled for the router to ride the rails and take off a small bite with each pass. lower the bit each pass until you have a level bench top.
I built a small set up for planing wood this way since I don't have a planer. I'd post a link to a picture of it, but don't have enough posts to be able to do that yet!
gts is offline
post #3 of 14 (permalink) Old 12-29-2009, 08:18 AM
gts
I should have added, I made my sled from angle iron. it needs to be wide enough that when you have the router all the way to one side of the bench, the sled is still riding the rail on the far side. Since I can't post links yet let me know if you want me to email or PM it to you.
gts is offline
post #4 of 14 (permalink) Old 12-29-2009, 08:50 AM
Gene Howe's Avatar
First Name: Gene
Good idea that! be sure to make the angle irons level with each other and use a sacrificial board between the iron and the surface to be leveled so that you can reach the edge and not contact the iron with the bit. I'd rig stops on the underside of the "sled" base.
Gene Howe is online now
post #5 of 14 (permalink) Old 12-29-2009, 11:10 AM
Cassandra's Avatar
First Name: Cassandra
Hi Greg:
Welcome to the forum and many thanks for the idea!
Cassandra
Carpe diem, quam minimum credula postero
http://www.panoramio.com/user/5924351
Cassandra is offline
post #6 of 14 (permalink) Old 12-29-2009, 11:13 AM Thread Starter
First Name: George
Greg,
Thanks so very much for the suggestion. I would very much like to see how you did it.
PM or email me, which ever is best for you..I'm in no hurry...my shop is not heated..
gcole55 at bellsouth dot net
Best Regards,
George Cole
"Regulae Stultis Sunt"
post #7 of 14 (permalink) Old 12-29-2009, 12:42 PM
curiousgeorge's Avatar
First Name: George
If all else fails try using the old fashioned method... a hand plane. I built a small work bench out of 2x6 pine also and that is how I leveled mine.
George
Fort Worth, Texas
City where the west begins.
curiousgeorge is offline
post #8 of 14 (permalink) Old 12-29-2009, 02:53 PM
gts
George, email sent. I can't take complete credit for the idea. I actually was posting pictures of my guitar build in a guitar forum and one of the guys saw my thickness planing jig and said it reminded him of a way of leveling the top of a beat up work bench.
As I told George in the email, the bit I used was a 1.25" mortising bit. That might be a tad small for an entire work bench surface though.
gts is offline
post #9 of 14 (permalink) Old 12-29-2009, 04:56 PM
Ghidrah's Avatar
First Name: Ronald
I built my original bench out of 2X6, nailed them in and never worried about truing the top up. After 22+ yrs. It's been pounded on with mallets, stabbed with chisles, cut into with jigsaws and circs, drilled you name it. The humps in the top where they occur never bothered me.
Ghidrah is offline
post #10 of 14 (permalink) Old 12-29-2009, 04:58 PM
Frank Lee's Avatar
First Name: Frank
Gene----Sounds great good plan, sounds like somthing I am planning. Frank Lee---Kingman AZ. Good Luck Post when you can.
Frank Lee is offline
Workbench Pictures -Sam- Show N' Tell 22 09-16-2009 07:11 PM
My new workbench kartracer63 Show N' Tell 9 03-25-2009 01:14 PM
Workbench I Microsuffer Microsuffer's Follies 8 03-16-2009 11:46 AM
workbench dogs Bogydave Starting Off 13 11-16-2008 04:46 AM
Ancient workbench with cam vice? petersenj20 Tools and Woodworking 3 05-27-2008 08:45 PM
