Bosch 1617 baseplate screw - Router Forums
post #1 of 13 (permalink) Old 12-27-2009, 07:51 PM Thread Starter
Country: Japan
First Name: Benny
Default Bosch 1617 baseplate screw
What kind of bit or tool do you use when you want to remove baseplate ?
Is it possible for you to get in a market ?
Or... you can get it only through Boach ?
I am glad if I could have informations.
Benny LaBaw is offline
post #2 of 13 (permalink) Old 12-27-2009, 08:08 PM
Hi Benny. Those look like what we call Torx head screws. Fairly easy to come by over here and Europe I think. You may just try a search on that term. A size T-20 is what I have in my Freud for the baseplate screws. Those look about the same. Next smaller size would be T-15 and next larger common size would be T-25.
John Schaben
jschaben is offline
post #3 of 13 (permalink) Old 12-27-2009, 08:17 PM
Just to add to John's post
Looks like a combo Torx,a strait screw driver blade should work on them also..
just need to use the right blade size..
post #4 of 13 (permalink) Old 12-28-2009, 01:05 AM Thread Starter
Country: Japan
First Name: Benny
Jhon san
Thank you for a info..
I went to Home Center to see it.
But as far as I verfy(?),it does not fit.
Thank you.
Bobj san
Thank you for your info..
I will try...a strait screw driver blade.
Thank you.
I mail to Bosch and a shop.
But No-answer.
A year-end holidays... maybe...
post #5 of 13 (permalink) Old 12-28-2009, 04:54 PM
Wizard1500's Avatar
First Name: Carl
You can use a straight screw driver, but be careful....it will strip easily....I just purchased an extra base for my Bosch to mount to a second plate, and I almost stripped one, while removing it.....
Wizard1500 is offline
post #6 of 13 (permalink) Old 12-29-2009, 05:58 AM Thread Starter
Country: Japan
First Name: Benny
John san
I went to specialty shop in down-town.
I could get it.
Just fit.
Thank you very much.
I wonder why driver in Home-Centre does not fit.
The reason is the one in Home-Centre is notorious Japan-Made, I guess...
I am too coward to use straight one.
post #7 of 13 (permalink) Old 12-29-2009, 11:24 AM
Talking
John san
I could get it.
Just fit.
Glad you found one. I admit I was a bit puzzled over your post indicating the one from Home Center didn't work.
Just be careful, those little screws strip out very easily. One of them on one of my Freuds was stripped when I got it. Freud was only using two or three of the threads so I replaced it with the next longer screw. I think they are M4.
John Schaben
jschaben is offline
post #8 of 13 (permalink) Old 12-29-2009, 07:35 PM Thread Starter
Country: Japan
First Name: Benny
Carl san
Thank you for your advice.
Many tipes of head is the evidence of stripping-failure, isn't it.
I will change base to Jasper's...
I have not known a meaning of "strip".
I can find it at 11th. explanation among(?) 12 expalanations in my Dic.
post #9 of 13 (permalink) Old 12-29-2009, 09:55 PM
BigJimAK's Avatar
Benny... "strip" = damage screw threads or slot
BigJimAK is offline
post #10 of 13 (permalink) Old 12-30-2009, 09:33 PM Thread Starter
Country: Japan
First Name: Benny
John san
Thank you.
Yes, I am glad I could get it.
At that time, shop-assistant said "I can not understand why it does not fit".
We did a bad choice, didn't we...
Anyway, I will be careful not to strip.
Bosch 1617 screw hole template bigroccrek Table-mounted Routing 6 09-04-2016 11:30 AM
Mixing Bosch 1617 Router fixed base with Craftsman professional router sf_basilix Starting Off 17 10-11-2012 05:20 PM
Screw sizes for the plunge base on Bosch 1617 deck99 Table-mounted Routing 6 12-20-2008 11:10 AM
Mounting Bosch Jigsaw to Router Baseplate - finished Ladd Table-mounted Routing 4 02-06-2008 05:47 PM
Which hole pattern should I get (plate for a Bosch 1617)? Nickbee Table-mounted Routing 1 11-23-2007 06:49 PM
