Freud router base for 3 1/4 hp FE2000 - Router Forums
post #1 of 10 (permalink) Old 12-09-2005, 09:34 PM Thread Starter
routerrookie's Avatar
Question Freud router base for 3 1/4 hp FE2000
undefinedundefinedundefined I want to either purchase or build a router table for my big boy router. However, I no idea where to look for hardware to attach my FE2000 to the table. All catelogues show tables for the other well known routers(PC, Dewalt, etc.). What can I use for mine?
routerrookie is offline
post #2 of 10 (permalink) Old 12-13-2005, 11:23 AM
Hickory's Avatar
You can buy the freud router table made for this router.Home depot sells them ..You can just buy the freud top and make the base . Or you can build it from scratch as they say.
It would be easier to buy the Freud Router plate for this router..its bored to fit the router...All you need to do is inset your top.ON this sight there are instructions how to do it. If you dont want to buy a Freud router plate, go to a window and door business and buy a piece of Lexon 3/8 thickness and the over all size you want..for eg 12 x 8 x 3/8
When you buy your own router plate you will need to bore it to fit your router base.
The important parts is making sure it is centred..There is probably information about that on here also.
Hope this helps Hickory
Hickory is offline
post #3 of 10 (permalink) Old 01-01-2006, 07:19 PM
Routerrookie,
Did you manage to find what you were looking for? If not and you need additional help, reply. I have the same router and I built a table for it.
Charlie5 is offline
post #4 of 10 (permalink) Old 01-29-2008, 07:30 PM
Default all LUCK
Hello , don't know if there is there is a time limit on replies , but I was in Lowe's last week and picked up the Freud table that was on sale. I asked the sales mang. what was the lowest he will go , and he said $44.00 . I said , "for the hole thing" and i don't see any more on display or anywhere in Lowe's so they may not be displaying them any more , so yal check
kenwho is offline
post #5 of 10 (permalink) Old 04-07-2008, 04:25 PM
Default Router Table for FE2000?
Hi, Routerrookie.
You mentioned you built a table for your FE2000. I realize that was some time back. But, I've had an FE2000 for a few years, and recently got a PC for handheld use. I'm interested in mounting my FE2000 under an as-yet-not-built-nor-designed router table. I was wondering if you had any advice for me, or even if you had plans you could offer.
Thanks!
Russell Richter
Houston, TX
Originally Posted by Charlie5
Routerrookie,
russellrichter is offline
post #6 of 10 (permalink) Old 04-07-2008, 05:20 PM
Dr.Zook's Avatar
First Name: Dave or "Doc"
Welcome to the forums Russell.
Dave
the "Doctor"
Dr.Zook is offline
post #7 of 10 (permalink) Old 04-17-2008, 12:14 PM
Does anyone have a source(Freud website appears not to have this) a drawing showing the layout of the holes and dimensions of the 2200 series routers?
Best regards,
John
servojohn is offline
post #8 of 10 (permalink) Old 04-17-2008, 01:04 PM
Hi John
You don't need the dimensions or the hole layout becasue you have them.. right on the router plate and it's always best to use the plate you have because it's right for your router.
see links below
http://wealdentool.com/acatalog/tips_23.html
http://wealdentool.com/acatalog/tips_20.html
Best regards,
John
post #9 of 10 (permalink) Old 04-21-2008, 09:40 AM
Charles M's Avatar
Best regards,
John
John,
Send me an email or PM with your email address and I will happily send you a pdf file of the mounting template.
Charles M is offline
post #10 of 10 (permalink) Old 04-22-2008, 08:40 AM
Charles,
Email: j_challiburton at sbcglobal don't forget the dot, net.
Originally Posted by Charles M
John,
To Charles,
Thanks so much, I'll pm you with my email address.
To Bob, I could go and spend time measuring the base layout physically, but I want to work up CAD drawings for a baseplate for table mounting, and possibly a sub base or two-especially a circle cutting base. It just makes things a bit more accurate with a real(and in this case, "factory")drawing of the product to go from.
I suppose I could have scanned the stock sub base and...
Best regards,
John
Last edited by servojohn; 04-22-2008 at 09:14 AM. Reason: Charles, couldn't pm you yet, post count too low.
Mixing Bosch 1617 Router fixed base with Craftsman professional router sf_basilix Starting Off 17 10-11-2012 05:20 PM
Model 320.17542 and table routing 46_trap Table-mounted Routing 44 10-16-2011 01:40 PM
