Plunge Router Lubricant - Router Forums
post #1 of 7 (permalink) Old 12-29-2009, 07:53 AM Thread Starter
rick7938's Avatar
Default Plunge Router Lubricant
What kind of dry lubricant would you suggest for the plunge posts to keep them operating smoothly?
Thanks for any suggestions.
rick7938 is offline
post #2 of 7 (permalink) Old 12-29-2009, 11:10 AM
Talking
Hi Rick, Welcome to the forum. I like the spray dry graphite lube from NAPA. Some guys will recommend candle wax also. I like the graphite because it is in some sort of liquid carrier that flashes off very quickly but still carries the powder into otherwise inaccessible places. Just gotta be careful applying it. If you get it on somewhere you don't want it is tough to remove.
Just my opinion, will be more along presently.
John Schaben
jschaben is offline
post #3 of 7 (permalink) Old 12-29-2009, 11:35 AM
Mike Wingate's Avatar
First Name: mike
Scotchbrite pad. Dust sticks to lubricant.
Mike Wingate is offline
post #4 of 7 (permalink) Old 12-29-2009, 12:40 PM
Hi Rick
I use a Teflon lube, that you can get from most hardware stores, you don't want to put anything on that will act like a magnet for router dust..most lubes are oil base or wax that you don't want to use..
post #5 of 7 (permalink) Old 12-29-2009, 12:42 PM
First Name: Gordon
I use a Silicon spray
stairman is offline
post #6 of 7 (permalink) Old 12-29-2009, 08:39 PM
RouterForums.com User
harrysin's Avatar
First Name: Harry
Silicon spray should be kept well away from wood, the most microscopic drop on a project will leave a blemish whatever finish is used.
I personally occasionally "spray" a minute amount of CRC on the pillars and that maintains a smooth plunge action, for me.
Harry
harrysin is offline
post #7 of 7 (permalink) Old 01-22-2010, 02:05 AM
First Name: Daniel
Johnson or Minwax paste wax. LPS 1 also works well.
St. Louis, MO
Retired Welding Inspector and past Ind Arts teacher
Clouseau is offline
Sticking Plunge Router lemonyx General Routing 9 03-25-2009 07:17 PM
Plunge router mounting on table Bram Table-mounted Routing 6 04-04-2006 03:22 PM
Plunge Router or combo Router??? deniscomeau Tools and Woodworking 4 03-14-2006 03:14 PM
