collets - Router Forums
post #1 of 4 (permalink) Old 12-12-2005, 05:39 PM Thread Starter
Default collets
tring to remove bits from collet after usin, i, have to hit bit to remove same.
watching rickand bob, on tv they don`t seem to have this problem
r1327 is offline
post #2 of 4 (permalink) Old 12-12-2005, 06:30 PM
Hickory's Avatar
You want to make sure that your collet is clean and also the router shank doesnt have a burr on it.
I wouldn't be hitting anything, you may damage the shaft on the motor,
You didnt say what kind of router you have.
Rick and Bob are using Porter-cable routers.The shows i have seen anyways.
The Collets on the porter-cable have what they call a Auto-release collet system and it ends "frozen" bits., and it works great.
You loosen the nut with both wrenches, then you turn it with your hand and about 1/2 way you will feel it release away from the bit..The bit then slides out easily.
.IT's the only router i know that has this feature.
Hickory
Hickory is offline
post #3 of 4 (permalink) Old 12-13-2005, 12:17 PM
I have a milwaukee router and it has the auto release. I use the two wrenchs to loosen the collet but after its loose it gets tight again near the end and I have to use the wrenches again and that is when it pops the bit loose.
garys is offline
post #4 of 4 (permalink) Old 12-14-2005, 09:22 AM
First Name: jerry
most of the newer routers have the bit releasing collets.
REgards
Jerry
jerrymayfield is offline
For Sale: Bosch Collets RustyW Woodworking Classifieds 3 04-17-2007 11:59 AM
Triton/Hitachi collets Rayinthe UK General Routing 1 09-12-2006 04:35 AM
1617 Bosch and 1/2 & 1/4 collets dtaylor15 General Routing 1 03-10-2006 05:07 PM
Freud 3 1/4 HP (1/4 collets) Del Delaplante General Routing 2 02-08-2005 12:27 PM
