Over arm pin router - Router Forums
post #1 of 8 (permalink) Old 01-01-2010, 06:46 AM Thread Starter
Gene Howe's Avatar
First Name: Gene
Default Over arm pin router
I just pulled mine out of storage and cleaned it up. When I last used it, I made a run of 24 wall mirror/plant holders. Really simple stuff.
Anyone use one a lot? Have you discovered some tricks or different uses for it?
I pulled it out of storage to make a bunch of toy parts. Again, pretty simple set ups and straight forward operations.
I'd like to use it for some relief "carving" with multiple templates, and some inlay work. Anybody done this?
Gene
Gene Howe is offline
post #2 of 8 (permalink) Old 01-01-2010, 09:21 AM
BigJimAK's Avatar
Gene,
I installed a pin router arm (Veritas) and a second (plunge) router (with a bitjack) in/on my RT a couple of months ago but haven't gotten to playing with it much yet. I've attached the manual, as starting about page 7 they cover basic use and copying and about page 14 they start covering inlay, creating filled cavities, sign work and reversed images. If you're interested, an overview of a bitjack is at the very end. This may give you a *little* more information.
Jim
BigJimAK is offline
post #3 of 8 (permalink) Old 01-01-2010, 09:46 AM Thread Starter
Gene Howe's Avatar
First Name: Gene
Thanks Jim!
Although my set up is with the router in the arm (top routing), The information in the PDF is certainly valid. I just skimmed it, but the info on inlay is going to be especially valuable.
Thanks again. Happy New Year and....stay warm!
Gene
post #4 of 8 (permalink) Old 01-01-2010, 11:18 AM
Hi Gene
Just one video,,I have both types of pin routers. then can do many jobs..but I will say you need to look into the ski way .. then you can put your pin router setup back into the corner
See video on web page...
MLCS daisy pin router
post #5 of 8 (permalink) Old 01-01-2010, 12:14 PM Thread Starter
Gene Howe's Avatar
First Name: Gene
Thanks, Bob.
Skis are on the horizon.
I just can't stand having this beast, and it is a beast, free standing, top mounted router, and, not using the darned thing.
Gene
post #6 of 8 (permalink) Old 01-22-2010, 02:01 AM
First Name: Daniel
Gene, what kind of pin router do you have. There are some tricks to getting nice finish cuts by using oversized pins or bushings and then taking a finish cut with a smaller pin. I have an old RL Carter that I am rehabbing and hope to have it going soon.
St. Louis, MO
Retired Welding Inspector and past Ind Arts teacher
Clouseau is offline
post #7 of 8 (permalink) Old 01-22-2010, 08:59 AM Thread Starter
Gene Howe's Avatar
First Name: Gene
Clouseau,
It was made by ShopSmith.
The stock pins are 1/4", 3/8" and 1/2". I am trying to find a machinist with a lathe small enough to turn some different diameters.
Gene
post #8 of 8 (permalink) Old 01-22-2010, 11:00 AM
First Name: Daniel
Can you post a couple pix of the pins and mount?
St. Louis, MO
Clouseau is offline
Mixing Bosch 1617 Router fixed base with Craftsman professional router sf_basilix Starting Off 17 10-11-2012 05:20 PM
Rigid Model R2900 Router Combo and Ryobi Model A25RT02 Router table bigdave720 Table-mounted Routing 12 04-05-2012 07:27 PM
Router Recall (PC, SEARS, RYOBI) Birdflu General Routing 5 02-23-2012 10:01 PM
How do I mount a Router to a table demaX Table-mounted Routing 3 04-16-2009 06:56 AM
