Hatachi M12VE Review - Router Forums
post #1 of 4 (permalink) Old 01-02-2010, 10:05 AM Thread Starter
Bob N's Avatar
First Name: Bob
Default Hatachi M12VE Review
For those who miss the M12V, there may be good news for you in 2010.
Gord Graff on blip.tv
Bob N is offline
post #2 of 4 (permalink) Old 01-02-2010, 10:55 AM
Hi Bob
Good video, but I think they miss the boat again, no lift kit built in many want one on the 3 1/4 HP router in the table, a simple threaded rod to the base would sale that router big time. plus I did not see a vac.pickup tube.
post #3 of 4 (permalink) Old 01-02-2010, 11:33 AM
First Name: George
Georgia Bob,
Thanks, I got carried away watching the rest of Gords videos..Great stuff..Thanks again,
George
"G"
George II is offline
post #4 of 4 (permalink) Old 01-02-2010, 11:44 PM
RustyW's Avatar
First Name: Rusty
That looks like a very good router. I think it's odd that there is no mention of the M12V2, almost as if it did'nt exist. A lot of people were making fun of the "look" Hitachi was going with, and it must have had an impact on sales. Since they have gone back to the guide adapter "ears" that most people cut off to clear large bits, and adjustable handles, I'm thinking it's designed to more of a handheld router. Rather than a table mounted router like my V2, which has the larger bit opening and springs designed to be easily removed(the VE may have the same spring setup, I don't know). As far as a lift kit, the V2 has a nut on the bottom end of the fine adjustment rod that has been punched to keep it from loosening. I'd bet the VE has the same, and a hole in the plate will let you access it from above. I did this with mine, but as mentioned many times by former Senior Mod Mike, your usually bending over to check the height at eye level. And at that point it's just as easy to adjust from below.
That guy has a very good video of the Mortise Pal. Making one similar to the one Trap built, has been on my to do list for a long time. But after seeing the video, I may keep saving my pennies for the real thing.
Rusty
If You Want It Bad, You Get It Bad The Worse You Want It, The Worse You Get It
RustyW is offline
Tool Review Guidelines ~ READ BEFORE POSTING Mark Tool Reviews 5 01-18-2020 09:11 AM
Router review KM12VC reible General Routing 15 11-23-2008 03:40 AM
Craftsman Fixed and Plunge Base Combo Review..... challagan General Routing 49 01-03-2008 12:06 PM
