Custom router insert - how big to make it? - Router Forums
post #1 of 3 (permalink) Old 01-03-2010, 03:27 PM Thread Starter
First Name: Royce
Default Custom router insert - how big to make it?
I am building a custom router table with a custom insert from a 3/8" x 12" x 12" polycarbonate blank. My Bosch router base is 6" in diameter, so I don't see any reason to make the insert any larger than about 6 1/2" x 6 1/2". Can anyone give me a reason to make it larger? It seems to me that the smaller the insert plate, the better, as long as the router can be removed through the hole in the table. What other consideration are there? Am I missing something?
RFickling is offline
post #2 of 3 (permalink) Old 01-03-2010, 03:31 PM
Mike Wingate's Avatar
First Name: mike
Will you be keeping the handles on the Bosch? You only really need 1/2" of ridge supporting the plate, but take cxare such a large one does not sag, I would make the plate smaller.
Mike Wingate is offline
post #3 of 3 (permalink) Old 01-03-2010, 03:39 PM Thread Starter
First Name: Royce
No, since this is to be a permanent mounting more or less, there is no need to keep the handles on the router. Yes, I am concerned about the plate sagging. I don't know how rigid polycarbonate is so I am trying to reduce the chance of that.
Router table insert template Durhamhs Table-mounted Routing 4 08-29-2009 01:45 PM
Router table insert cbrittain Table-mounted Routing 7 06-01-2009 09:22 AM
Woodhaven #147 Router Table Insert deck99 Table-mounted Routing 5 10-17-2007 02:06 PM
Router table insert question simplenik Table-mounted Routing 4 02-15-2006 11:18 AM
