double half-blind dovetails - Router Forums
post #1 of 4 (permalink) Old 01-03-2010, 07:43 PM Thread Starter
First Name: DREW
Default double half-blind dovetails
Does any know how to make dovetails like this?
Ministers Humidor - Fine Woodworking
I have the porter-cable 4212 dovetail jig. Something tells me its not as easy as just using the jig.
atmartin23 is offline
post #2 of 4 (permalink) Old 01-03-2010, 07:51 PM
TwoSkies57's Avatar
Drew,, head on over the the Porter Cable web site, bring up their dovetail jigs and follow the links to the manuals. They explain how that is done in detail. That particular joint is on my short list of learning how to's.. *S*.. its abeauty ain't it!!!.. I can't say which rig was used to make that particular box, but a good guess would be one along the lines of an Incra. Not technically incredibly difficult, but a very demanding "getting it right" kinda thing I would think..
TwoSkies57 is offline
post #3 of 4 (permalink) Old 01-03-2010, 07:58 PM
Hi
It can be done easy with the OakPark jig,see the video on the link below.
dovetail or the box joint it's works on both the same way..
Or you can use the small Incra jig for the same type of job.
Router Workshop: dovetailliner
http://www.rockler.com/product.cfm?p...al%20precision
post #4 of 4 (permalink) Old 01-04-2010, 11:48 AM
rwyoung's Avatar
First Name: Rob
TwoSkies has it right. You can find the supplementary manual for the 4212. The key is changing bit sizes. First you cut the larger size sockets and a pin board. Glue up and cut "flush". Then switch to a smaller bit size and cut again.
Other than having a couple different sizes of D.T. bits, I believe the other key is NOT changing any settings of the jig between runs.
And as Bob pointed out, other jigs can do this too. In fact, you can do it by hand.
rwyoung is offline
Half Blind Router Template Question stevek433 Guide Bushings and Templates 5 02-06-2009 08:23 AM
Incra jig and rabbeted half blind dovetails S Bolton Jigs and Fixtures 10 08-24-2007 01:06 PM
