routing the groove on a cutting board - Router Forums
post #1 of 4 (permalink) Old 01-04-2010, 04:26 PM Thread Starter
Default routing the groove on a cutting board
Greetings to the woodworkers on this forum. I live in Victoria BC and I make stuff in little bits of spare time.
I use a lot of pallet wood. Right now I'm making a new cutting board for our kitchen out of pallet oak.
I am trying to figure out how to make the little groove around the edge follow the curve of the corner on three corners, but bypass the corner which has the handle extension. I'm using a 3/8" round router bit which is on a straight shank. Whether I rout the groove on my table, or rout it hand held with guide boards, the corner won't do what I want it to do. There must be some really simple solution. Any great insights out there?
Grandadpjp is offline
post #2 of 4 (permalink) Old 01-04-2010, 05:31 PM
Hi Peter
You just need to make a quick template and pickup a pattern bit,sq. template ,just glue up some sticks to make a quick template, once dry stick the template to the cutting board, plunge down and go all the way around the inside of the template and your done..
C1661 Core Box Pattern Bit, 1/4" Shank
Grizzly.comŽ -- Online Catalog
Or you can go over the top by using the bit below to get that special look
http://grizzly.com/products/Classica...-4-Shank/C1673
post #3 of 4 (permalink) Old 01-04-2010, 07:48 PM
Dr.Zook's Avatar
First Name: Dave or "Doc"
Welcome Peter, to the RouterForums. Glad to have you as a member.
Dave
the "Doctor"
Dr.Zook is offline
post #4 of 4 (permalink) Old 01-05-2010, 01:15 AM
xplorx4's Avatar
First Name: Jerry
Greetings and welcome to the router forum. Thank you for joining us.
Lamentations 3:22-23
xplorx4 is offline
oak for cutting board? Birch The Finishing Touch 41 09-26-2018 05:10 PM
Cutting groove in cutting board Ken Brown Jigs and Fixtures 7 01-06-2010 09:57 AM
Cutting a curved groove rsmtg New Member Introductions 3 09-25-2008 10:56 PM
Cutting board and dovetail joinery rzaccone Table-mounted Routing 2 05-12-2006 10:14 AM
Cutting Board woody Show N' Tell 3 04-02-2006 03:32 PM
