Fixed base routers - Router Forums
post #1 of 11 (permalink) Old 01-04-2010, 04:47 PM Thread Starter
istracpsboss's Avatar
Country: Croatia
First Name: Peter
Default Fixed base routers
Hi guys
I know a lot of you use fixed base routers and the combined packages are regularly mentioned, too.
I'm intrigued as to why anyone would want a fixed base router as they appear to be much harder to use, with no obvious advantage. They also seem unknown outside North America. I cannot recollect ever seeing one in use in Europe, in recent years, even though German manufacturers still seem to produce them for the North American market.
What am I missing, please?
Cheers
Peter
istracpsboss is offline
post #2 of 11 (permalink) Old 01-04-2010, 05:20 PM
Hi Peter
They are easy-er to use than the plunge base,,they can slip right out of the base , 1,2,3 and they are out and you can change the bits out very easy and quick..
here's some shots of one I have setup..
Originally Posted by istracpsboss View Post
Hi guys
Cheers
Peter
Name:	plastic plate A.jpg
Name:	old router table.jpg
Name:	old router table AB.jpg
post #3 of 11 (permalink) Old 01-04-2010, 06:23 PM
First Name: Jimmie
As the owner of 6 routers, 2 are plunge and 4 fixed, I can truthfully say the fixed based routers are used abouut 80% of the time. As to why anyone would want a fixed based router, I can only speak for myself, I much prefer using the fixed router but do use the plunge routers when necessary. Robbie
robersonjr is offline
post #4 of 11 (permalink) Old 01-04-2010, 06:42 PM
First Name: Duane
IMHO,
Fixed base are much less bulky, weigh less, easier to maneuver, and are easier to adjust height in or out of the table. Plunge bases have their place for sure though. But a majority I feel can be accomplished with the fixed base.
Maybe its because they are more readily available at a discounted price so we Americans tend to buy them 1st making us more used to them ?
Duane867 is offline
post #5 of 11 (permalink) Old 01-04-2010, 11:22 PM
RustyW's Avatar
First Name: Rusty
Well, when joined here, I only had experience with fixed base routers. Plunge routers looked to be to complicated to even mess with. Now I have 2 plunge only routers and a combo. The fixed base for the combo sits, unused, in a drawer. It would be well suited for table use, but I use a large plunge in my table. The only fixed router I now use is my Bosch Colt. For me I just prefer the way the plunge router adjusts, both in and out of the table.
Rusty
If You Want It Bad, You Get It Bad The Worse You Want It, The Worse You Get It
RustyW is offline
post #6 of 11 (permalink) Old 01-05-2010, 12:11 AM
Talking
Hi Peter - I'm a bit new to routers but in the last year I've managed to accumulate two combo kits and two fixed bases. The fixed bases are dedicated, one to dovetails and the other to table use.
I really like the combo kits because it allows me to choose the best configuration for the job. I like the fixed base for edge work, dados and rabbits. Bit height is much easier and precise, visibility is far better as is the balance and general handling. The plungers are obviously superior in any operation where you need to enter or exit the cut within the workpiece.
Just my .02
John Schaben
jschaben is offline
post #7 of 11 (permalink) Old 01-05-2010, 01:38 AM Thread Starter
Country: Croatia
First Name: Peter
Hi Peter
Tks Bob
So mostly for table use ? BTW, I bet fitting those hinges to your plate was a test of skill to get the plate fitting spot on.
Cheers
Peter
post #8 of 11 (permalink) Old 01-05-2010, 01:42 AM Thread Starter
Country: Croatia
First Name: Peter
Originally Posted by Duane867 View Post
IMHO,
Hi Duane
Maybe and I guess they are cheaper to produce, but I never see them in Europe at any price anyway.
Cheers
Peter
post #9 of 11 (permalink) Old 01-05-2010, 01:54 AM
I use them for many operations like, dovetails, edge profiles, trim bits, & hanging doors. They are lighter, less bulk, & quick to use. They have their place.
Whittier, CA.
Have a nice & safe day!
jlord is offline
post #10 of 11 (permalink) Old 01-05-2010, 08:41 AM
Ghidrah's Avatar
First Name: Ronald
I never altered my plunge for the table, (remove springs) it made bit height setting during table use a pain, but I was using it as much on the job as in the shop.
I always found the plunge more versatile than the fixed base. But in the table the fixed base and lift are king in my book.
Ghidrah is offline
Intro and question john spies New Member Introductions 20 12-08-2018 11:08 AM
Mixing Bosch 1617 Router fixed base with Craftsman professional router sf_basilix Starting Off 17 10-11-2012 05:20 PM
Hello DPugmire New Member Introductions 5 11-08-2010 06:29 AM
Converting fixed base to plunge base. -Sam- Portable Routing 4 09-30-2004 03:53 PM
