Help with 12mm Cutter shaft - Router Forums
post #1 of 9 (permalink) Old 01-17-2010, 09:41 AM Thread Starter
Default Help with 12mm Cutter shaft
Hey Guys,
I have recently bought a trend biscuit cutter with a 12mm shaft rather than 1/2 inch. I didnt know that there would be much difference. I have a makita 3612cx and was wondering if there a an attachement to convert and use the cutter.
Andy
andysubaru3089 is offline
post #2 of 9 (permalink) Old 01-17-2010, 10:10 AM
Hi Andy
Most biscuit cutters have a 8mm hole in them, so to say use one of your other router bit shanks with the 8mm shank on it..
Trend U*T370X1/4TC GUIDED BISCUIT JOINTER 5/32 CUT | Ace.Tool.com - The Tool Experts
Originally Posted by andysubaru3089 View Post
Hey Guys,
Andy
post #3 of 9 (permalink) Old 01-17-2010, 12:53 PM
Mike Wingate's Avatar
First Name: mike
Is there a 1/2" collet for your router?
Mike Wingate is offline
post #4 of 9 (permalink) Old 01-17-2010, 12:56 PM
First Name: mike
post #5 of 9 (permalink) Old 01-18-2010, 12:46 PM Thread Starter
Yes, its a 1/2 inch router, but it just seems to be a bit slack. All other 1/2 inch router cutters are 12.7mm. Just wondering if there was a way for this to fit with reducer
post #6 of 9 (permalink) Old 01-18-2010, 02:40 PM
istracpsboss's Avatar
Country: Croatia
First Name: Peter
Do not use an 12mm shank in a 1/2" collet. If you manage to tighten it enough to grip you'll probably ruin the collet and if you don't the bit will come out and give you an unpleasant surprise.
There are reducers available for 8mm
4 pc Collet Reducer Bushing for 8mm, 1/4" Router Bit - eBay (item 140371773484 end time Feb-02-10 16:30:44 PST)
but for 12mm you'll need an actual 12mm collet as there would be insufficient wall thickness to create a 1/2" to 12mm one.
They are certainly available for DeWalts 12MM ROUTER COLLET FOR DEWALT DW625EK on eBay (end time 06-Feb-10 16:44:23 GMT) and I would have thought Makita do them for the European market. You didn't say where you are from, though.
Cheers
Peter
istracpsboss is offline
post #7 of 9 (permalink) Old 01-18-2010, 04:03 PM Thread Starter
From Inverness,Scotland. Yeah so i need to buy i need collet altogether. So why do they sell 12mm and not 1/2inch, bit silly is it not
post #8 of 9 (permalink) Old 01-18-2010, 04:50 PM
Country: Croatia
First Name: Peter
Looks like you got an oddball one. Did you get it directly from them ? Their webpage shows 1/2" shanks
http://www.trend-uk.com/en/JA/produc..._jointers.html
If you got it directly, see if they will swap it.
Cheers
Peter
post #9 of 9 (permalink) Old 01-18-2010, 04:54 PM
First Name: mike
Weatherwatch. derek willis Table-mounted Routing 11 02-14-2009 03:41 AM
Top bearing sliding up shaft MisterHeavy Router Bits - Types and Usage 3 04-28-2008 02:02 AM
Machining flats on band saw shaft Kristin D Tools and Woodworking 2 12-18-2007 12:34 PM
Special rabbet/rebate cutter..... challagan Router Bits - Types and Usage 8 01-31-2007 06:58 PM
Slot Cutter or Spline cutter kimbert General Routing 3 10-20-2005 06:26 PM
