Bosch 1617 ESV fine adjustment question - Router Forums
post #1 of 6 (permalink) Old 01-20-2010, 10:12 PM Thread Starter
First Name: Joe
Default Bosch 1617 ESV fine adjustment question
Just got a used Bosch 1617 ESV off ebay. I've been checking every thing out and there seem s to be an issue with the fine adjustment. It is binding at about the middle of the adjustment range. Is this a problem with this Bosch model in general or do you think there's something wrong with this particular unit? I did take the motor out of the base and checked the adjustment threads. There did not appear to be saw dust or chips causing the problem. Maybe I'm not seating the motor properly in the base? Need some help so I can decide to keep it or send it back.
horn man is offline
post #2 of 6 (permalink) Old 01-20-2010, 10:38 PM
First Name: Daryl
I'm jealous. I want one of those. I'm waiting for Lowes to put them on sale but I think that I am wasting my time. I just wrote to Bosch and asked them when it would be on sale or if they have any coupons or rebates that would help to get the price down.
sofasurfer is offline
post #3 of 6 (permalink) Old 01-21-2010, 01:33 AM
I always rub the motors down with Johnson's Paste Wax on my 1617's and any router with a removeable motor. Let the wax dry then buff it off with a clean rag. That seems to keep them operating very free plus they go in and out of the bases easily.
It's cheap and might help your situation.
Tom Hintz, Publisher
NewWoodworker.com
Tom Hintz is offline
post #4 of 6 (permalink) Old 01-21-2010, 01:51 AM
Here's a reconditioned one.
Factory Reconditioned Bosch 1617EVSPK-RT 2.25 HP Combination Plunge & Fixed-Base Router Pack
John Schaben
jschaben is offline
post #5 of 6 (permalink) Old 01-21-2010, 05:59 AM
Cassandra's Avatar
First Name: Cassandra
+1 on the waxing. I had the same problem with the bases binding. Cleaned up any rough edges on the sliding surfaces and then wax the motor unit. Works a treat. Have to re-wax once in a while, but that's nothing when one keeps a good router running.
Cassandra
Carpe diem, quam minimum credula postero
http://www.panoramio.com/user/5924351
Cassandra is offline
post #6 of 6 (permalink) Old 01-21-2010, 05:07 PM Thread Starter
First Name: Joe
I actually thought about doing that, but the stupid side of my brain said that's too obvious, its got to be the fine adjustment mechanism. Well, sure enough, I applied some wax (and a little moly lub on the fine adjust threads), and voila', everythings as smooth as a newborn's backside!
Oh yeah, I had been thinking about getting one from Lowes' also, since they seemed to have the best new price anywhere. Then the other side of my brain kicked in (the cheap side) and I was able to snatch a used one up off ebay for a $100.00 less delivered than Lowes. Only moderate wear on the fixed base plate and the plunge base doesn't even look like its ever been used.
horn man is offline
Bosch 1617 router base problem bill kay General Routing 35 05-30-2016 08:39 AM
Mixing Bosch 1617 Router fixed base with Craftsman professional router sf_basilix Starting Off 17 10-11-2012 05:20 PM
New member question about trouble with a Bosch 1617 EVS SD tinkerer New Member Introductions 5 09-26-2009 05:07 PM
Which hole pattern should I get (plate for a Bosch 1617)? Nickbee Table-mounted Routing 1 11-23-2007 06:49 PM
