Bosch Colt - tilt base setting - Router Forums
post #1 of 2 (permalink) Old 01-29-2010, 10:56 PM Thread Starter
wm_crash's Avatar
First Name: Cosmin
Default Bosch Colt - tilt base setting
Hi,
I have a Bosch Colt with the tilt base. I need to make all sorts of cuts, often at unconventioanl angles. What is the best procedure to get the base tilted as accurately as possible to the desired angle?
I have both a Beall TiltBox and a protractor from Lowes. The protractor looks like this:
Thanks in advance.
. . . and now a little background on my question . . . I was trying to get a 7.5 degree angle on a piece of wood . . . . I fixed a straight bit and got it to 7.50 with the tilt box . . . then I made some cuts, then I bought the protractor . . . . I measured and it was more like 9.5 to 10.0, can't tell exactly . . . then I pulled the tilt box out and measured the angle of the cut, and I also got like 9.8 . . . something isn't right.
cheers,
wm_crash, the friendly hooligan
wm_crash is offline
post #2 of 2 (permalink) Old 01-30-2010, 09:48 AM Thread Starter
wm_crash's Avatar
First Name: Cosmin
OK, I messed up and used the wrong image in the post above. The protractor I have is a "180 Ground Stainless Steel Protractor". A quick search on the web will bring up the item.
cheers,
wm_crash is offline
Bosch 1617 router base problem bill kay General Routing 35 05-30-2016 08:39 AM
Mixing Bosch 1617 Router fixed base with Craftsman professional router sf_basilix Starting Off 17 10-11-2012 05:20 PM
Bosch Laminate Routers - old accessories with new (Colt) zzdodge Portable Routing 2 08-12-2009 08:34 AM
Sold: Bosch Colt router with loads of accessories **SOLD** Bob N Woodworking Classifieds 1 06-23-2009 07:12 PM
Colt plunge base bobj3 Jigs and Fixtures 19 04-01-2008 07:54 PM
