why is centering cone needed? - Router Forums
post #1 of 10 (permalink) Old 01-31-2010, 04:17 PM Thread Starter
First Name: Daryl
Default why is centering cone needed?
I don't have one yet but I am just trying to learn a little.
Why is a centering cone needed? Why isn't the base plate just MADE TO BE CENTERED instead of being made to be inacurate? Seems like a very easy thing to do.
sofasurfer is offline
post #2 of 10 (permalink) Old 01-31-2010, 07:19 PM
Ghidrah's Avatar
First Name: Ronald
Its helpful for centering "new" base plates for screw holes, and when using template guides. some bit diameter to inside guide diameters can be very tight, an offset of 1/128" can mean disaster.
I can't speak for all 2nd party plate manufacturers but all the extra non (OEM) plates I ever bought don't come with alignment ribs like the PC default plates do. As tight as the (default) plates fit even they need to be checked when tight tolerances are in effect.
Ghidrah is offline
post #3 of 10 (permalink) Old 01-31-2010, 07:47 PM
Hi
You don't need to buy a cone you can make your own very easy and it 's a must thing you must do on all routers and mounting plates..
You can use plastic or some scrap stock from the shop.
They stamp out the base plates and most are not dead on the norm.
post #4 of 10 (permalink) Old 01-31-2010, 10:00 PM
Noob's Avatar
First Name: Paulo
Hi
That is one of them "That is so simple, why didn't I think of that" little jigs, thanks for the tip... because I was wondering how do you make one without a lathe.
Noob is offline
post #5 of 10 (permalink) Old 01-31-2010, 10:27 PM Thread Starter
First Name: Daryl
Ok, either I am having a "duh" moment or I'm just not that smart, but how the heck do you make those little centering guides. A hole saw? Cut out the disk and try to make a centered hole? Make the center hole and cut a circle around it? Come on, don't assume I get it cause I don't
post #6 of 10 (permalink) Old 01-31-2010, 10:52 PM
Hi
I use the hole saw to puch them out but I do cheat a little bit, I use the jig below to get them just right and on dead center, in about 2 min. job.
Note ::you can clamp the jig on the other side of the sander as well ( the round disk side with the flat plate)
Plus it's neat and easy way to make wheels for toys or the offset rings for the brass guides..
post #7 of 10 (permalink) Old 01-31-2010, 10:58 PM Thread Starter
First Name: Daryl
Aaaa-haaaa!!
You guys sure do know your way around the shop, don't you?
I see what your trying to tell me. Very clever. Thanks.
post #8 of 10 (permalink) Old 02-01-2010, 06:37 AM
Noob's Avatar
First Name: Paulo
I'm glad you asked soda.
Noob is offline
post #9 of 10 (permalink) Old 02-01-2010, 10:02 AM
You're Welcome sofasurfe
It's great little jig and can do many jobs..I use it all the time.
Try it with two dowel pins in place, a easy way to get a radius just right
Aaaa-haaaa!!
post #10 of 10 (permalink) Old 02-01-2010, 11:50 AM
Mike Wingate's Avatar
First Name: mike
Hole saw. Mount disc blank on its shank/mandrel. Chuck in drill press or lathe, abrade to shape with tool of choice until it fits. No jigs to make. Somewhere I have seen a really neat and simple disc sander jig. Back to the books. Nice one Bob.
Mike Wingate is offline
Centering your router on a mounting plate Mike Table-mounted Routing 61 01-08-2016 10:28 AM
Makita 3612 collet nut and collet cone needed cheap Zappacat General Routing 5 07-18-2009 12:33 PM
centering cone rout1111 Router Bits - Types and Usage 3 07-13-2009 03:54 PM
Router selection help needed robdunstan Table-mounted Routing 19 02-14-2008 03:37 PM
Centering Base Plate -Sam- General Routing 15 01-04-2005 10:15 AM
