14' long arch -- how to? - Router Forums
post #1 of 12 (permalink) Old 02-01-2010, 06:57 AM Thread Starter
allthunbs's Avatar
First Name: Ron
Default 14' long arch -- how to?
I have a series of 14' long arches/partial ellipse/partial oval, 6" high and 1" thick that I have to produce. The problem is the radius of the arch would be some ridiculous length, impossible to scribe.
Suggestions?
Allthunbs
allthunbs is offline
post #2 of 12 (permalink) Old 02-01-2010, 09:12 AM
Suggestions?
Hi Ron, is that the amount of arc over the 14', 6"? I think I would draw the thing out, to scale, on deltacad or sketchup and take measurements every 6" or so to plot out a full size template. go from there.
John Schaben
jschaben is offline
post #3 of 12 (permalink) Old 02-01-2010, 09:47 AM
Hi Ron
I have a jig for just that type of job,,,it's bowl and arrow type jig, a stick with a string..set it and they all come out the same....
I have not posted it b/4 but I will if you want to see it..
oR
Flexible Curve Ruler, some have lead in them but the one below is plastic,the lead ones are better and will hold the shape you set up. (lead ones from Grizzly)
use the item below
Router accessories 3
Suggestions?
post #4 of 12 (permalink) Old 02-01-2010, 10:26 AM
Use 2 finish nails set at 14'. Rip a flexible 1/2" stick out of a 16' 2x4 run longer than 14'(1/2" x 1-1/2" no knots) or something similar. Find center & push to your 6" rise. Scribe the outside of flexible stick. Move nails up 1" & repeat for your 1" thickness. The arc should be 16.34*. You didn't say if the 6" was an inside or outside measurement. Just adjust for that but 2 finish nails & a flexible stick should be all you need to accomplish your task.
Whittier, CA.
Have a nice & safe day!
jlord is offline
post #5 of 12 (permalink) Old 02-01-2010, 01:11 PM
Ghidrah's Avatar
First Name: Ronald
Are you making headers or arched ceilings or trellises?
I think ellipses and ovals are pretty much the same thing, "a stretched out circle" although one is stretchier... er than the other. How accurate, (symmetric) the ellipse/arch is to be depends on the number of blocks and their positions are on the ply.
In the past I've made a couple 3 arched garage door overheads and breezeways.
In your case a sht of ply ripped in half along the 8' and 2X to hold them tight together.
Block the ends with 2X for the 14'W and a block in the center at the 6"H.
Pressurize a water hose from the house, thoroughly bleed all the air before closing off the end, (good water pressure helps) keep the house feed open.
Set the hose in the jig, butt it to the blocks and mark the perimeter.
Ghidrah is offline
post #6 of 12 (permalink) Old 02-01-2010, 02:14 PM
First Name: Daryl
Doesn't anyone watch This Old House? Tom will show you how to do it...
http://www.youtube.com/watch?v=so81BLxh4yA
sofasurfer is offline
post #7 of 12 (permalink) Old 02-01-2010, 02:39 PM
Rick R. of the RWS will so you a easy way on the The Woodworking Channel Video Library ,see part two of the Oval mirror ..
All done with a small framing square
post #8 of 12 (permalink) Old 02-01-2010, 04:00 PM
Bob I think he needs 14' long not 14"
Whittier, CA.
jlord is offline
post #9 of 12 (permalink) Old 02-01-2010, 05:34 PM
Hi James
Your right I didn't see that, I didn't know he was a making train trestle.
post #10 of 12 (permalink) Old 02-01-2010, 08:01 PM Thread Starter
allthunbs's Avatar
First Name: Ron
Hi Ron, James, Sofasurfer:
This is part of a design theme throughout the house and outside. It is an attempt to unify all of the parts, the terrace in the back, break up the central wall with built-ins, and become a design element in the kitchen and bathrooms.
I figure the 14' ones will be "sort of" but once one is created, the others are easy duplicates. The interior ones will be 4'-6' and will be much easier to do but will be one-off each.
Excellent mechanics. Well worth the examination and attempt.
The carport is 28' long with two "bays" between pillars supporting the roof. The front and back are 14'. These are "detail panels" that go below the beams and hide indirect lighting. Would you use a single circular arch, an ellipse or an oval?
Thanks for the help guys.
Allthunbs
Long Bit mi77915 Router Bits - Types and Usage 6 08-24-2009 09:48 AM
Very Long Pivot Fence mcelduff Table-mounted Routing 2 01-12-2009 07:41 AM
Long winded hello PCrosby2 New Member Introductions 5 07-19-2008 11:42 AM
How long would you say I have? tpyke Tools and Woodworking 1 02-16-2008 05:29 PM
sliding dovetails on long boards Neanderthal Portable Routing 5 09-21-2007 08:42 AM
