setting depth for plunge router - Router Forums
post #1 of 9 (permalink) Old 02-03-2010, 10:46 AM Thread Starter
mag_rules's Avatar
First Name: mike
Default setting depth for plunge router
I have a Black & Decker Fire-Storm Plunge Router, FS1200RP and I'm fairly new at using a plunge router. any tips on how to easily adjust hieght. I was cutting a 3/4 dado into mdf 1/4 deep. It took me a long time to get the depth correct. I was trying to measure from the base to the end of the bit, but it seemed like i needed three hands. I know it has depth adjustments but if you dont put the bit in at exactly the same depth everytime won't they be off? I'm just looking for some tips for an easy way to set the depth for my plunge router. Thanks.
mag_rules is offline
post #2 of 9 (permalink) Old 02-03-2010, 10:59 AM
Hi Mike
It's best to use the pole stop on your plunge router..the easy way is to use some sq.brass bars if you don't have a set you can use some drill bits.
Just pop in the router bit,zero out the bit to the stock, put the dill bit under the pole stop and pull it down and lock it..then you are dead on every time.
post #3 of 9 (permalink) Old 02-03-2010, 11:54 AM
Mike Wingate's Avatar
First Name: mike
I use the shanks of twist bit drills to set the depth (as above).
Mike Wingate is offline
post #4 of 9 (permalink) Old 02-03-2010, 12:31 PM Thread Starter
mag_rules's Avatar
First Name: mike
okay mike, I'll be using drill bits. I assume the pole stop is the udjustable pole on my router. When u say zero out the bit to the stock, what exactly do you mean?
Also, i kinda get what you're saying, if i want to make a 1/4 depth put a 1/4 drill bit under the pole stop then adjust it?
post #5 of 9 (permalink) Old 02-03-2010, 12:41 PM Thread Starter
mag_rules's Avatar
First Name: mike
sorry i meant to reply to Bobj3, I'll be using drill bits. I assume the pole stop is the udjustable pole on my router. When u say zero out the bit to the stock, what exactly do you mean?
post #6 of 9 (permalink) Old 02-03-2010, 12:49 PM
Hi Mike, Set your router on top of your stock and plunge down so your bit touches the top of your material. Then take your sized drill bit to use as spacer & set the depth stop with your drill bit under stop nut. That will set total plunge to include depth of cut.
Whittier, CA.
Have a nice & safe day!
jlord is offline
post #7 of 9 (permalink) Old 02-03-2010, 12:51 PM
Hi Mike
Zero out the bit,,once the bit is in the collet, push the router down till the bit is just on the stock =zero the bit out..lock the router in place than put the drill bit under the pole stop let it drop down on the 1/4" drill bit, than lock it and your set to put in a 1/4" deep slot or what every you want to set it at...
post #8 of 9 (permalink) Old 02-03-2010, 12:55 PM Thread Starter
mag_rules's Avatar
First Name: mike
okay, I got it. I will try it possibly tonight. That does sound very easy. Man, why do i always overthink stuff. Thanks for the replies.
post #9 of 9 (permalink) Old 02-03-2010, 12:58 PM
Your Welcome Mike
It will be like putting your shoes once you have done it a time or two..
I think my old router nearly killed me! peacefrog General Routing 23 01-26-2014 11:36 AM
Sears Plunge Router Model 315.275110 Wally99 Table-mounted Routing 3 12-24-2008 06:39 AM
Router Bit Depth odamsr Router Bits - Types and Usage 3 09-06-2005 10:45 AM
