Help With Math (no not the new math) - Router Forums
post #1 of 14 (permalink) Old 02-03-2010, 04:05 PM Thread Starter
Default Help With Math (no not the new math)
Ok, I have a hex shaped box (in this case an aquarium) to build. If the dia is 18" (measured from one side to the other) what is my length on each of the six sides and what angle would I route to?
I just went as high as High School Algebra, the rest of the time I spent in Shop Class all through high school)
thanks Charles
lemonyx is offline
post #2 of 14 (permalink) Old 02-03-2010, 04:20 PM
kp91's Avatar
First Name: Doug
search "circumscribed hexagon", you should find the formulas
1 John 1:9
Fredericksburg, VA
kp91 is offline
post #3 of 14 (permalink) Old 02-03-2010, 05:06 PM
Ghidrah's Avatar
First Name: Ronald
D=18
PI=3.14159
DXPI= 56.54
Divide 56.54 by the number of facets required
Ghidrah is offline
post #4 of 14 (permalink) Old 02-03-2010, 05:18 PM
The short answer is .577 times the distance across the flats. Cut your pieces at 30 degrees. When the parts are assembled you will have 60 degree joints. Six sides equal 360 degrees for a circle.
Whittier, CA.
Have a nice & safe day!
jlord is offline
post #5 of 14 (permalink) Old 02-03-2010, 06:20 PM Thread Starter
Thanks for the help everyone
lemonyx is offline
post #6 of 14 (permalink) Old 02-03-2010, 07:03 PM
thanks Charles
Hi Charles - I haven't got a clue what the math is so I drew it out in DeltaCad and it comes out 10 3/8". You wanted 18"dia across the inside of the flats, right?
John Schaben
jschaben is offline
post #7 of 14 (permalink) Old 02-03-2010, 09:36 PM
Noob's Avatar
First Name: Paulo
+1, This is the easiest method to find the length of the flats.
18 x .577 = 10.386, which is within .006" of the exact flat length.
18 x .5773 = 10.3914, which is within .0009" of the exact flat length.
Noob is offline
post #8 of 14 (permalink) Old 02-03-2010, 10:48 PM
OK, I gotta ask, where did the .577 come from???
John Schaben
jschaben is offline
post #9 of 14 (permalink) Old 02-04-2010, 12:59 AM
MarcoBernardini's Avatar
Country: Italy
First Name: Marco
Send a message via MSN to MarcoBernardini
It is the tangent of 30 degrees, actually 0.577350269 (according to Google calculator).
See Tangent - Wikipedia, the free encyclopedia
MarcoBernardini is offline
post #10 of 14 (permalink) Old 02-04-2010, 03:47 AM
Red face
Guess I should have spent more time in geometry class..
Now that I understand that part, I think we only answered half the question.
It doesn't look like we accounted for stock thickness. Gonna need to add 2x stock thickness to the diameter.
John Schaben
jschaben is offline
Miter guage math Enticer Jigs and Fixtures 1 10-21-2006 06:28 PM
