Help for routing doors - Router Forums
post #1 of 9 (permalink) Old 02-04-2010, 03:36 PM Thread Starter
Default Help for routing doors
I am fairly new to routing techniques even though I have used routers for a long time for edge relief. I want to learn how to rout MDF slab doors for my cabinets to match (or close to it) existing doors. I am building all the cabinets myself. The upper existing doors are all cathedral cut, I want to make the lower doors square cut at the top.
barrylb is offline
post #2 of 9 (permalink) Old 02-04-2010, 06:37 PM
On vacation
First Name: Tom ( Template Tom)
Barry.. Welcome to the forum; there are many here who can assist you getting what you want to do with a router. This project is quite simple to achieve with the aid of template guides, also a face/edge cutter. It does require making a simple jig. I can assist you if you forward more details simply PM me with the size required. Just a reminder; there is more that can be achieved when the router is held in the plunge mode, with the aid of template guides. Check out the material below.
Tom
(Template Tom)
P.S. Arched doors below but the square ones are easier to make
Tom76 is offline
post #3 of 9 (permalink) Old 02-04-2010, 06:47 PM
Hi Barry
The bit is the key, once you have the one that will match the doors you have, it's easy...
You can make a template or just use some sticks for the bearing to run on..
C1681 Classical Plunge Pattern Bit, 1/2" Shank
Grizzly.com® -- Online Catalog
post #4 of 9 (permalink) Old 02-04-2010, 08:58 PM
xplorx4's Avatar
First Name: Jerry
Greetings and welcome to the router forum. Thank you for joining us.
Lamentations 3:22-23
xplorx4 is offline
post #5 of 9 (permalink) Old 02-04-2010, 09:29 PM
On vacation
The method I used to rout the pattern on the door was to use a template guide and a Face/edge cutter. It just means you make your template that little bit larger also the template material does not have to be greater than 12mm
Tom
(Template Tom)
Name:	40mm Guide.jpg
Tom76 is offline
post #6 of 9 (permalink) Old 02-04-2010, 10:02 PM
But with your guide setup you must use a 40mm guide to let the bit in side the guide,but with the bearing on the bit no guide is needed..so to say the template or sticks can be a true pattern size..no math needed,plus it's very hard to get a 40mm guide in the states..as you know.
Plus by using the bearing way you can add the bearing to just about any bit profile .
adaptor bushings and ball bearing guides
post #7 of 9 (permalink) Old 02-04-2010, 11:47 PM
Dr.Zook's Avatar
First Name: Dave or "Doc"
Hi Barry. Welcome to the RouterForums. Glad to have you with us.
Dave
the "Doctor"
Dr.Zook is offline
post #8 of 9 (permalink) Old 02-08-2010, 01:20 AM Thread Starter
Thanks Tom,
My router is an older Craftsman I've had for probably 20 years. It is not a plunge router. I would like to find a nice Porter Cable plunge to go with the one I have. I still have 2 cabinets to build and not sure of the door width yet. The height is 22 1/4 inches. As soon as I can figure out posting a picture, I will show what I am trying to duplicate or approximate.
barrylb is offline
post #9 of 9 (permalink) Old 02-08-2010, 01:29 AM
On vacation
Thanks Tom,
Look forward to your next posting, There was some comment that you would need a 40mm guide which is not true all you require is a guide large enough for the cutter to penetrate through. You will require a plunge router no matter what method you do choose the cutter with the bearing added on top will require a thicker template if it is to be used with safety.
Tom
(Template Tom)
Tom76 is offline
Bathroom cupboard doors locoboy Show N' Tell 6 01-19-2012 11:47 AM
Raised Panel Doors Diane Horner New Member Introductions 5 01-06-2010 08:50 AM
French Doors & Mullions - Router Bit? FrenchDoor Router Bits - Types and Usage 20 10-09-2009 09:04 AM
We produce 400 passage doors per month. Thoughts on using CNC machine? Rmarsh CNC Routing 5 02-22-2008 09:21 AM
