need table - Router Forums
post #1 of 4 (permalink) Old 02-09-2010, 10:31 AM Thread Starter
Default need table
i own the ridgid combo kit and am dying for a table but have no idea what to look for. i believe my router comes witha T handle thats supposed to allow me to adjust the bit height from the top of the table does this mean i need a special table??
killahkid is offline
post #2 of 4 (permalink) Old 02-10-2010, 12:35 AM
CanuckGal's Avatar
First Name: Deb
Hi Nick and welcome! You won't need a special table but you may need to modify the mounting plate in whatever table you choose in order for the handle to fit through it and into the router. It's a simple matter of drilling a hole in the proper spot.
Take a look around in the Table Mounted Routing section of the forum for different member's tables. There are many home made ones and commercial ones in use by different members. You may get some ideas to help you out in your quest!
I measured, I marked, I cut.
CanuckGal is offline
post #3 of 4 (permalink) Old 02-10-2010, 06:41 AM
xplorx4's Avatar
First Name: Jerry
Greetings Nick and welcome to the router forum. Thank you for joining us. I have that same router. Deb is correct, just drill a hole where needed to access the hight adjustment. You may want to concider building your own router table. If you decide to make your own, you can get lots of help here.
Lamentations 3:22-23
xplorx4 is offline
post #4 of 4 (permalink) Old 02-11-2010, 01:01 AM
Dr.Zook's Avatar
First Name: Dave or "Doc"
Hello Nick, and welcome to the RouterForums. Happy to have you join us.
Dave
the "Doctor"
Dr.Zook is offline
Help with router and table djonesax Table-mounted Routing 31 08-27-2012 06:10 PM
Oak, Octagonal Drum Table. derek willis Show N' Tell 18 02-25-2009 09:20 AM
Novice router question RonH General Routing 10 02-02-2009 09:07 PM
Router Table Help Which One! bigroccrek Table-mounted Routing 25 04-08-2008 10:57 PM
