Removing Router Burns In Maple - Router Forums
post #1 of 13 (permalink) Old 02-12-2010, 10:03 AM Thread Starter
First Name: Mack
Default Removing Router Burns In Maple
Hello to all,
Does anyone have any tips for removing router burn marks from maple with out going over It again with the router, sanding or scraping? If i do any of those, It will cause deformation because it a very detailed shape. Will bleaching the wood work? I have since learned how to prevent this from happening again. Thanks for any advice.
Regards,
Mack.
mack. is offline
post #2 of 13 (permalink) Old 02-12-2010, 10:42 AM
BigJimAK's Avatar
I don't have a great solution for you, since I use a scraper. If I had to accomplish it, I'd likely use the bit in scrap to make a template and then use a Dremel to shape the edge of an old scraper to fit.
There's likely an easier approach.
BigJimAK is offline
post #3 of 13 (permalink) Old 02-12-2010, 02:40 PM
Hamlin's Avatar
First Name: Ken
A sharp bit would've helped prevent burning also, the same goes with the speed in which you moved either the material or router.
There are detailed sanders on the market, your best choice is, sand it.
Ken
"A VETERAN"
Hamlin is offline
post #4 of 13 (permalink) Old 02-12-2010, 03:41 PM Thread Starter
First Name: Mack
Thanks Big Jim and ken for your hep.
Mack.
mack. is offline
post #5 of 13 (permalink) Old 02-12-2010, 04:43 PM
Hi
I will 2nd Jm's post but add a note, you can use the bit for the scraper just rap a rag around the bit and go to work on the burn mark..you will get it out if it's not to deep.
post #6 of 13 (permalink) Old 02-13-2010, 07:46 AM Thread Starter
First Name: Mack
Hi
Hi Bob3,
Thanks for your response. Are you saying to take the bit out of the router wrap a piece of cloth around it and use It as a scraper? Thanks again.
Mack
mack. is offline
post #7 of 13 (permalink) Old 02-13-2010, 10:10 AM
Hi Mack
Right on, it's the right profile
Originally Posted by mack. View Post
Hi Bob3,
Mack
post #8 of 13 (permalink) Old 02-13-2010, 12:09 PM Thread Starter
First Name: Mack
Thanks BobJ, and everyone else.
Mack
mack. is offline
post #9 of 13 (permalink) Old 02-13-2010, 01:44 PM
BigJimAK's Avatar
Mark... I'm sure this was obvious from the get-go to everyone but me but I read it and asked myself "how will it cut with a rag around it" but then realized Bob was talking about the *other* side of the bit.
BigJimAK is offline
post #10 of 13 (permalink) Old 02-13-2010, 09:28 PM Thread Starter
First Name: Mack
I wasn't sure myself, thats why I asked for clarification to make sure. It seems like a good idea that may work.
Mack
mack. is offline
Router Recall (PC, SEARS, RYOBI) Birdflu General Routing 5 02-23-2012 10:01 PM
Router table ideas Larwyn Table-mounted Routing 4 12-28-2009 01:47 AM
Router table refurb- Woodpeckers Unilift rstermer Table-mounted Routing 14 11-03-2009 12:21 PM
Router table or Plunge routing template tom Guide Bushings and Templates 15 04-14-2009 02:45 AM
