Help please i'm new to routers - Router Forums
post #1 of 21 (permalink) Old 02-12-2010, 09:41 PM Thread Starter
First Name: Cory
Unhappy Help please i'm new to routers
I have just order a router off of ebay it is a cheap chicago 1-1/2 hp plunge router with only a 1/4" collet, I purchased it so I could bull nose my stair treads. They are 2"x12" treads so I think I need a 3/4" roundover bit but I can only find it in a 1/2" shanke. can I buy an after market collet or other brand collet to fit my router or can someone provide me with a link to a sight that sells it with a 1/4" shanke. I should have resurched what I needed before purchasing but it was a great deal and I only had about 2 sec. left in the auction so I bought it. I always wanted a router and now I have one even if it will not work for this project. Thanks for any help you can offer.
clyoung333 is offline
post #2 of 21 (permalink) Old 02-12-2010, 09:42 PM Thread Starter
First Name: Cory
also can I use a plunge router on a router table?
post #3 of 21 (permalink) Old 02-12-2010, 10:09 PM
Talking
Hi Cory - welcome to the forum
Boy, I have one of those bits and it is a pretty good chunk of steel to be balanced on the end of a stick about the size of a pencil. Then spin it at 20,000 rpm + Me thinks that would be a plan General Custer himself could be proud of.
Seriously, you may be able to find a bit like that from some Chinese outfit, not particularly concerned with safety but I doubt you will find anything of meaningful quality. Actually, for stairs, a 1/2" radius should work for you and they are readily available.
As far as a collet goes, I think Chicago refers to Chicago Electric which is a Harbor Freight house brand and I doubt you will be able to find a 1/2" collet for it either.
In reference to your question about table mounting it, yes, many have plunge routers table mounted. Most of the larger, 3+ hp, routers aren't even available in fixed base.
Sorry I couldn't be more positive... Someone else will likely jump in here soon with some other thoughts.
Thanks for joining, will be looking forward to hearing more from you.
John Schaben
jschaben is offline
post #4 of 21 (permalink) Old 02-12-2010, 11:25 PM Thread Starter
First Name: Cory
Thanks John you have been helpful, but I do have a question. I thought that bull nose was a full radius of the edge and a 1/2" rad. will not get a full rad. on a 2" board or maybe I am not thinking about quite right. again I am a newbie and need some experience with my new toy. Thanks again any knowledge will be helpful.
post #5 of 21 (permalink) Old 02-12-2010, 11:47 PM
Dr.Zook's Avatar
First Name: Dave or "Doc"
Hello Cory, and welcome to the RouterForums. Glad to have you join us.
Dave
the "Doctor"
Dr.Zook is offline
post #6 of 21 (permalink) Old 02-12-2010, 11:52 PM
Smile
OK - I misunderstood. A 3/4" roundover bit will give you a 1-1/2" bullnose. If you want a full bullnose on a 2" board you will need a 1" radius roundover... even bigger!! A 3/4" roundover would leave about 1/2" flat surface along the center of the stair, 1/2" roundover would leave a 1" flat surface. Neither are a bad thing, just a matter of taste.
You also should consider the diameter of the bit as well as the shank size. My 3/4" roundover is 2" in diameter. This is an extremely large bit and not usually considered a safe bit in the hand held mode. I run mine on the router table. There are some here that have the skill to handle such a bit safely hand held but I am not one of them. Also, some routers haven't got the throat capacity to handle that of large of a bit. The 1/2" roundover will be about 1-1/2" in diameter and, I think, most standard (1-1/2 hp up) should take it with no problem.
Hope this helps
John Schaben
jschaben is offline
post #7 of 21 (permalink) Old 02-13-2010, 12:04 AM
Talking
Hi again - I don't know what you have for bits but here is a reasonably comprehensive set that won't break the bank. Will give you a fair selection of capabilities you can experiment with and decide how you want to go.
30 pc 1/4" Shank Router Bit Set - eBay (item 140378372949 end time Feb-26-10 18:55:40 PST)
John Schaben
jschaben is offline
post #8 of 21 (permalink) Old 02-13-2010, 12:55 PM Thread Starter
First Name: Cory
John, thanks again your advice it helps greatly. I will try a 1/2" bit to see how it looks (i.e. see if the wife likes it) and go from there. I know they make bits that remove wood but they have not invented the bit that will put it back on yet. Thanks again, Cory.
post #9 of 21 (permalink) Old 02-13-2010, 02:17 PM
DerekO's Avatar
First Name: Derek
I think I have that exact router. Still in the box, going dowstairs to use it once I get done reading messages on here and my email.
DerekO is offline
post #10 of 21 (permalink) Old 02-13-2010, 07:52 PM
Good idea, the BOSS doesn't like it we back to square one.... At least find out before you do it....
John Schaben
jschaben is offline
2 Extra Routers What To Do With?? Steve B General Routing 17 02-28-2010 07:40 PM
Need 6 routers F3RR3T General Routing 14 10-21-2009 06:14 PM
Triton Routers DougO General Routing 32 11-17-2008 01:48 PM
New Craftsman Routers foleylink General Routing 2 11-10-2007 11:48 PM
Freud routers and tables cabinetsetc General Routing 6 11-06-2005 05:06 PM
