Triton MOF001 worm gear - Router Forums
post #1 of 13 (permalink) Old 02-14-2010, 10:08 AM Thread Starter
Default Triton MOF001 worm gear
Does anyone know when Triton will change the material that the TRA378 worm gear is made of and when it'll be available?
After changing my router table to fit a new Triton MOF001 bought online in May 2009 The micro-adjuster wouldn't work. It would allow the router to lower OK but when trying to raise the router it would lift about 1/16" and drop back again after each full rotation of the crank handle. The free plunge and rack and pinion plunge worked perfectly. Removing the plunge spring was no help. After re-reading the operator manual several times and checking the table and router for obstructions, loose screws, etc. I decided to return it for warrenty repair.
Checking the Triton website was no help whatsoever in getting info on where and how to have the work done. Calling the USA office, 1.888.874.8661, got nothing but a bizarre computer message that that number could not be reached from my calling area. This started me on a general web search for help with the problem.
The first thing I found was that several people had the same problem and that the design was rumored to be being studied for a change of the worm gear material. The second thing found was an excellent website for servicing the MOF001, raygirling.com/dismmofl.htm , that also has a link at the very end on servicing the TRA001. Thirdly I found that the Tridon line is now being distributed in the USA and Canada by HTC Products Inc. On the HTC website I found and called a number that was answered by a human, a human that spoke english, explained the problem and within a minute the part was on it's way.
A week later the part arrived and I replaced the broken worm by using Ray Girlings instructions. I now use the micro-adjuster for fine adjustments only, course adjustments and bit changes are done by using the rack and pinion or free plunge knobs. When raising the router I assist the micro-adjuster by helping it lift with my free hand. The plunge spring will only be re-installed when the router is off the table.
The router now works great but I'd like to buy another worm gear after the material change is made just to have on hand. I hope that Triton improves their communication with North American customers as to warrenty procedures.
2jawchuck is offline
post #2 of 13 (permalink) Old 02-14-2010, 03:12 PM
Community Founder
Mark's Avatar
First Name: Mark
Welcome to the community Charles!
Mark,
Founder of RouterForums.com
Mark is offline
post #3 of 13 (permalink) Old 02-15-2010, 12:29 AM
Dr.Zook's Avatar
First Name: Dave or "Doc"
Hello Charles, welcome to the RouterForums. Happy to have you join us.
Dave
the "Doctor"
Dr.Zook is offline
post #4 of 13 (permalink) Old 02-15-2010, 04:19 AM
Thumbs up
Hi Charles - Welcome to the forum
Nice piece of detective work, to bad you had to. Sorry, can't help with the Triton.
John Schaben
jschaben is offline
post #5 of 13 (permalink) Old 02-16-2010, 06:38 AM
istracpsboss's Avatar
Country: Croatia
First Name: Peter
Ray Girling is a good guy. He used to be a demonstrator for Triton.
Cheers
Peter
istracpsboss is offline
post #6 of 13 (permalink) Old 02-18-2010, 03:39 PM Thread Starter
Ray Girling's service manual for the MOF001 is the best repair manual I've ever seen. It protected me from a couple of mistakes I'm certain to have made without reading it. Triton would be wise to buy the rights to it from him.
Thanks for letting me know where he got his expertise with Triton.
Chuck
post #7 of 13 (permalink) Old 08-29-2012, 11:09 AM
Default Update on Triton worm gear: METAL worm gear available!
There is a well-known issue with the plastic worm gear with the Triton MOF001 router such that, with time or possible improper use, it will strip. Micro-adjusting, especially when used in a router table using the crank, brings it up about 1/16" inch, then it falls back down. The only work-around is to take the router out of the table, thus taking the weight off of the gear, and use the micro adjust with the router on its side.
2jawchuck gave some very helpful information, including the name of a company, HTC, that used to distribute Triton. They no longer do, but they gave me the number of the new distributor, which is: 1-855-227-3478. I believe this is a US toll-free number. I do not yet have the name of the distributor, but when I get it, I will try to remember to post it.
I called them, got routed to a guy named Stacy, who was familiar with the problem with stripped plastic worm gears. He took my name and address and told me he was mailing me a new METAL replacement gear that should prevent this problem from recurring. He also took my email address and said he would send a link to a video that would show me how to replace the plastic worm gear with the replacement gear. He did not request payment for the replacement part, even though I have had my router for a few years.
Mark Colan is offline
post #8 of 13 (permalink) Old 08-29-2012, 02:50 PM
Default New Triton distributor; videos for router repair
I got an email from Avail Distribution, the current distributors for Triton in US. They sent me the URL for a page with several videos related to the Triton MOF001 router, including one telling you how to replace the worm gear for micro-adjust.
This news poster program refuses to let me post the URL for the page for the videos that tell you how to replace the worm gear, among other repair tasks for the Triton routers. If you go to google, and type
avail infovideos.html
google will show you what to click.
Note that I did not actually type a URL, just told you how to find it.
post #9 of 13 (permalink) Old 08-29-2012, 03:14 PM
Avail Distribution - Available Products
post #10 of 13 (permalink) Old 08-29-2012, 08:32 PM
Harrison67's Avatar
First Name: Harrison
I don't even own a Triton, but thanks for the videos, Bob.
Very informative.
Harrison67 is offline
Important information regarding TRITON harrysin Lobby 1 01-05-2010 08:08 PM
Update on WORM GEAR wil141 Table-mounted Routing 3 10-04-2009 01:02 PM
Problems with Triton in Table. hgporter Table-mounted Routing 4 06-12-2009 11:18 AM
Table for Triton MOF001 socalrascal Table-mounted Routing 3 08-18-2008 06:22 PM
Triton MOF001 S Bolton General Routing 4 12-27-2007 07:11 PM
