Routing Bull nose Flutes - Router Forums
post #1 of 2 (permalink) Old 02-18-2010, 02:18 PM Thread Starter
Default Routing Bull nose Flutes
Looking for some guidance for routing a closed end bull nose flute in a style.
The styles I have milled are 1" thk by 2 1/4" wide and are 17" long. They have a tenon cut on each end. Doug Fir.
I'd like to add a nice detail to the face. So, I'm planning to plow a 14" long flute down the middle of the face with a 3/8" bull nose router bit.
I have a router table with an adjustable fence, but the styles are a little longer then the fence so I don't have room to clamp a stop. The table also has feather boards but I'm not sure how to use them if I have to drop the workpiece down on the bit to start the flute.
I guess I could mark the fence on the leading edge with tape and use as a guide to stop, turn the piece around and repeat, then clean up the middle but if the work is not centered perfectly over the bit I could get some mismatch.
Any techniques or suggestions to plow a flute using a router table would be greatly appreciated.
bambam is offline
post #2 of 2 (permalink) Old 02-18-2010, 02:35 PM
Hi George
Here's easy jig you can make to put in flutes all day long and they will all come out right on the button every time..
http://www.routerforums.com/jigs-fix...19549-jig.html
Forum Suggestion Thread Mark Site Help and Suggestions 131 02-08-2015 09:33 AM
Bull nose bit set at Amazon, $37.37 caliban The Bargain Bin 1 06-22-2008 01:27 PM
Bull nose help please!! Tally Jigs and Fixtures 90 09-08-2006 10:57 PM
bull nose pedro New Member Introductions 3 06-16-2006 02:07 PM
Routing end grain Pop_pop1 Table-mounted Routing 8 09-22-2004 12:24 PM
