Maximum Shank Extenstion - Router Forums
post #1 of 4 (permalink) Old 02-19-2010, 09:29 AM Thread Starter
First Name: Walter
Default Maximum Shank Extenstion
How much of a 1/4" router bit's shank needs to be in the collet?
Blackduck is offline
post #2 of 4 (permalink) Old 02-19-2010, 12:38 PM
istracpsboss's Avatar
Country: Croatia
First Name: Peter
Most of it. Put it all the way in as far as it will go and ease it back out a 1/16" so that it has slight movement capability when the collet pulls it in.
Cheers
Peter
istracpsboss is offline
post #3 of 4 (permalink) Old 02-19-2010, 01:12 PM
Stefang's Avatar
First Name: mike
All the manufactures tell you it should be in at least 3/4 of the way.
Mike, an American living in Norway
Theory is when one knows everything, but nothing comes out right.
Experience is when everything comes out right, but no one knows why
In my shop theory and practice are united. Nothing comes out right and nobody knows why.
Stefang is offline
post #4 of 4 (permalink) Old 02-19-2010, 01:50 PM
If you check your collet on the your router the bit should be to the bottom of the collet almost all collet nuts clamp the router shank right at the top of the collet nut, but it's best to have the shank all the way into the collet ..and maybe down just a little bit more.
Here's a snapshot of just some of the collet nuts and how they work..
Long shank core box bits Jon W. Branstrator Router Bits - Types and Usage 3 10-10-2009 03:24 PM
Reduced shank spiral bits??? jschaben Router Bits - Types and Usage 7 07-19-2009 09:57 AM
1/2 or 1/4" shank for beginner bill0199 Router Bits - Types and Usage 9 06-21-2009 10:44 AM
1/4" shank vs 1/2" shank Robbie Starting Off 5 01-06-2009 06:51 PM
3/4" Radius roundover bit with 1/4" shank chrisogrady Router Bits - Types and Usage 8 04-01-2005 08:08 PM
