routing into corners - Router Forums
post #1 of 22 (permalink) Old 02-24-2010, 05:20 PM Thread Starter
First Name: shane
Cool routing into corners
hi, I am currently changing single to double glazing on hardwood windows. Can anyone sugest a make or model of router that allows me to rebate the inside of a window frame?Need to cut as tight into inside corner as possible but edge of my plunge router stops 2 inches out.Any sugestions?
massey148 is offline
post #2 of 22 (permalink) Old 02-24-2010, 06:43 PM
tdublyou's Avatar
First Name: Tim
A small laminate trimmer with an offset base should get you fairly close.
What is the base running into that stops it from going into the corner?
Tim
tdublyou is offline
post #3 of 22 (permalink) Old 02-24-2010, 07:04 PM
Hi shane
The only router I know about with a true off base is the Bosch Colt,it will get right into the corners.
Amazon.com: BOSCH PR004 Offset Base With Roller Guide for the BOSCH Colt PR20EVSK & PR20EVSNK Palm Routers: Home Improvement
Amazon.com: Bosch PR20EVSNK Colt Installers Kit 5.7 Amp 1-Horsepower Fixed Base Variable Speed Router with 4 Assorted Bases and Edge Guide: Home Improvement
post #4 of 22 (permalink) Old 02-24-2010, 07:22 PM
tdublyou's Avatar
First Name: Tim
Bob,
There are others out there. They are usually classified as laminate trimmers rather than routers but they will do the job. I had a Makita years ago that would cut to within 1/2" of a corner. It was one of the handiest tools I had on my truck when doing trim work. Unfortunately it fell victim to a break in of my truck along with about $5000.00 in other equipment that I got about .50 on the dollar from my former insurance company for.
Tim
tdublyou is offline
post #5 of 22 (permalink) Old 02-24-2010, 07:31 PM
Hi Tim
I have many trim routers like the one below but I have not seen one that could get in the corners like the Colt, almost all come with a attachment ..but most can't get in tight.
I should say I have cut off the base on one but the motor holds them back..from the corner or the wall.
Amazon.com: Makita 3707FC Fixed Base Laminate Trimmer with LED Light: Home Improvement
post #6 of 22 (permalink) Old 02-24-2010, 07:38 PM
tdublyou's Avatar
First Name: Tim
Bob,
The one I had had the arbor offset from the motor and it was gear driven.
Hardly a week goes by that I don't wish I still had that little guy.
Tim
tdublyou is offline
post #7 of 22 (permalink) Old 02-24-2010, 07:57 PM
Hi Tim
I would love to see that one ,do you have a link to it
Originally Posted by tdublyou View Post
Bob,
Tim
post #8 of 22 (permalink) Old 02-24-2010, 08:36 PM
tdublyou's Avatar
First Name: Tim
Hi Tim
Bob,
No I don't but I might have a line on one. Called my brother up in Stevens Point because I thought he had one as well and he thinks he does. If he finds it he's sending it down to me. If it shows up I'll post a picture.
Here's hoping!
tdublyou is offline
post #9 of 22 (permalink) Old 02-24-2010, 08:51 PM
did a bit of digging
BettyMills: Laminate Trimmers - Makita 458-3700B
source=froogle2&utm_source=froogle2&utm_medium=cpc &utm_campaign=parts&utm_keyword=MAK458-3700B&utm_content=Facility
Makita 3708FC - Tilt Base Laminate Trimmer with L.E.D. Light - Chapman Electric Supply, Inc.
post #10 of 22 (permalink) Old 02-24-2010, 08:58 PM
tdublyou's Avatar
First Name: Tim
Similar but I think my base had more of an offset. It's hard to see from those pictures.
My brother just called and he found it.
I should have it within a week. Will post photo when I get it in my hands.
Tim
tdublyou is offline
Forum Suggestion Thread Mark Site Help and Suggestions 131 02-08-2015 09:33 AM
New to Routing and already lost!!! sarahrodgers New Member Introductions 10 12-31-2012 11:30 PM
New at Routing, Signmaking, Skiing TorontoBoy Sign Making 25 10-22-2012 07:59 AM
Routing Inside corners Al Robins General Routing 6 08-04-2009 03:54 AM
Router table or Plunge routing template tom Guide Bushings and Templates 15 04-14-2009 02:45 AM
