what is the collet holder part name please? - Router Forums
post #1 of 4 (permalink) Old 02-25-2010, 09:23 PM Thread Starter
pierogti's Avatar
First Name: Piero
Default what is the collet holder part name please?
the part which holds collet in place when you tighten or loosen the bit? is it a spindle lock? for craftsman router
thanks
pierogti is offline
post #2 of 4 (permalink) Old 02-25-2010, 10:02 PM
thanks
Hi - Welcome to the forum
Not sure if you are asking about the collet nut? That's the thing that thread onto the end of the armature shaft over the collet.
John Schaben
jschaben is offline
post #3 of 4 (permalink) Old 02-26-2010, 12:11 AM
istracpsboss's Avatar
Country: Croatia
First Name: Peter
May be called a closing nut?
What make is your router?
Cheers
Peter
istracpsboss is offline
post #4 of 4 (permalink) Old 02-26-2010, 12:23 AM
Country: Croatia
First Name: Peter
Just spotted your other post. Yes, it sounds like you've broken the spindle lock. How did you manage that? They are generally fairly robust.
Cheers
Peter
Makita 3600BR collet assembly and bearing removal vjeko Router Bits - Types and Usage 8 03-23-2015 01:14 AM
help please! what is the part that holds the collet called? pierogti Router Bits - Types and Usage 3 02-26-2010 08:11 AM
Already Problems neuschu New Member Introductions 11 12-15-2009 07:01 AM
Makita 3612 collet nut and collet cone needed cheap Zappacat General Routing 5 07-18-2009 12:33 PM
Installing bits in a tight collet Rowantree General Routing 8 07-09-2009 10:51 AM
