carpet tape? - Router Forums
post #1 of 9 (permalink) Old 03-04-2010, 01:52 PM Thread Starter
Default carpet tape?
I've been reading a lot of posts about using carpet tape to adhere a template to the work piece. Is this the best way to do it? does it actually hold the template firm enough to use as a guide? And is there residual glue or adhesive left on the piece when you separate them?
Thanks,
Dan
deacon76 is offline
post #2 of 9 (permalink) Old 03-04-2010, 02:00 PM
Cochese's Avatar
First Name: C
As far as I know.
yes
yes. At least with the one I used. Yellow, cheap kind from the Borg.
Thanks,
Dan
Cochese is offline
post #3 of 9 (permalink) Old 03-04-2010, 09:28 PM
Yes the carpet tape works great for this purpose. It is double sided. I use it for cutting out the patterns on raised paneled doors. As far as residue just don't leave in on for long periods like day's. Any residue is usually taken off during the sanding process.
Whittier, CA.
Have a nice & safe day!
jlord is offline
post #4 of 9 (permalink) Old 03-05-2010, 02:20 AM
My local big box store always has cheap and more expensive two-sided carpet tapes. When I used the cheap stuff the hold was not real secure and there might be some residue left behind. When I used the more expensive brand (3M?) it held great and didn't leave anything behind when removed. I also figured that the actual cost-per-use was stupid small so I quit sweating a few bucks and use the expensive stuff.
Tom Hintz, Publisher
NewWoodworker.com
Tom Hintz is offline
post #5 of 9 (permalink) Old 03-05-2010, 07:27 AM
Gene Howe's Avatar
First Name: Gene
I use the fiberous stuff from WalMart's paint section. It's Duck brand and cost is about 3 buck a roll. (50' IIRC). It holds VERY well. To separate, I just dribble lacquer thinner in the seams, or, if small parts, immerse them. Thinner will also completely remove the residue.
The tape is pressure activated so I will hit it with a rubber mallet or clamp it in the bench vise before routing.
Gene Howe is offline
post #6 of 9 (permalink) Old 03-05-2010, 08:02 AM
First Name: del
Default carpet tape
i get mine from a cabnet shop It is real thin and it hold's like it is nailed down I wouldn't use the thick stuff Maybe a little movement ? The name is intertape polymer group Made in sarasota florida here is one dist.
Adhesive Tape
and another google search
del schisler
port st. lucie, florida
del schisler is offline
post #7 of 9 (permalink) Old 03-05-2010, 11:43 AM
Thanks,
Dan
Hi Dan - I have had carpet tape slip on me, including some of the brands previously mentioned. I suspect the main reason was I tend to be a bit stingy with it. Whenever possible I prefer a pinner. Can leave small holes but generally easy to take care of. JMHO
John Schaben
jschaben is offline
post #8 of 9 (permalink) Old 03-05-2010, 12:01 PM
curiousgeorge's Avatar
First Name: George
A lot of people don't realize that carpet tape (the cloth back type) is pressure sensitive. The more pressure you put on it the harder it holds. Therefore, I suspect, the people who have trouble with it moving have neglected to pressure the pieces together. I would not suggest using this on thin pieces as you may break the piece trying to get the tape to release.
George
Fort Worth, Texas
City where the west begins.
curiousgeorge is offline
post #9 of 9 (permalink) Old 03-05-2010, 12:03 PM
levon's Avatar
First Name: levon
i use a brand called manco. it wont slip is very thin and very sticky!
BUT, i also agree with John on the pinner. i hardly ever use tape anymore since i got a pin nailer.
https://www.hardwareworld.com/2x75ft...e-pTVE3XP.aspx
levon
levon is offline
Omnijig 24 Model 7116 Instructional Tape mglesh Jigs and Fixtures 6 09-20-2013 08:32 AM
Not all 2 sided tape is created equal! Old_Chipper General Routing 12 08-17-2009 02:31 AM
Outdoor Carpet Tape FD_Cox Guide Bushings and Templates 8 05-04-2009 10:01 AM
double sided tape? falcn63 General Routing 4 01-17-2006 01:48 PM
