Groove routing around corners - Router Forums
post #1 of 4 (permalink) Old 03-08-2010, 12:38 PM Thread Starter
First Name: Raughn
Default Groove routing around corners
Does anyone have an idea for a jig that will route an inset groove on a rounded corner? I'd like to keep the edge distance consistent with the setback on the straight portion of the piece.
Raughn is offline
post #2 of 4 (permalink) Old 03-08-2010, 01:05 PM
Hi Raughn - Welcome to the forum
Member here, BobJ, posted a jig in here a week or so ago that does just that, plus a couple of other tricks. He likely has it posted in his gallery, I'm not to sure just where off hand. It was kind of an oval base with bearings instead of a fence for guides. He may be along later and repost it.
John Schaben
jschaben is offline
post #3 of 4 (permalink) Old 03-08-2010, 01:45 PM
First Name: Greg
Raughn,
would something like this work?
Greg
gregW is offline
post #4 of 4 (permalink) Old 03-08-2010, 03:39 PM
Hi
Here's a shop made jig that will do the same as the picture and PDF file Greg posted plus many others as well, it's a very simple jig to make, you can use the bearings off your other router bits or you buy some off MLCS at the right price.
http://www.routerforums.com/jigs-fix...19549-jig.html
http://www.rockler.com/product.cfm?p...0fluting%20jig
*********8
routing the groove on a cutting board Grandadpjp General Routing 3 01-05-2010 01:15 AM
Routing Inside corners Al Robins General Routing 6 08-04-2009 03:54 AM
Routing groove in door edges pablo 2009 General Routing 2 05-23-2009 05:13 PM
Routing a decorative groove on an inside curve HanDan General Routing 2 03-15-2006 03:43 PM
Curved Groove Routing ? Jackalope Jigs and Fixtures 4 03-10-2005 03:29 PM
