Router lube. - Router Forums
post #1 of 3 (permalink) Old 03-10-2010, 12:35 AM Thread Starter
justascratch's Avatar
First Name: Kevin
Default Router lube.
I'm sure this has probably been asked before.
So I'll ask it again.
At which points should I lubricate my router,
how frequently,
and which lubes are best ?
I've heard that Lithium grease is a popular lubricant.
Thanks for all the responses.
I'll try to reply sometime soon.
Thanks,
Kevin
justascratch is offline
post #2 of 3 (permalink) Old 03-10-2010, 12:56 AM
gav
Country: Croatia
First Name: Gavin
All the different opinins can be found here....
http://www.routerforums.com/tools-wo...brication.html
gav is offline
post #3 of 3 (permalink) Old 03-16-2010, 04:51 AM
dutchman 46's Avatar
First Name: Howard
I try to stay away from lubes as much as possible. The unit is taken care of in the factory. If You get it on a nice piece of wood that You are going to stain, the piece will not stain properly. instead, use a good rubdown with a clean cloth, or a steel wool. and do a good polish if necessary. Keep it clear of any silicone products
John 3:16
dutchman 46 is offline
Router Recall (PC, SEARS, RYOBI) Birdflu General Routing 5 02-23-2012 10:01 PM
Which Router To Get Etc? Gaia General Routing 10 02-24-2010 04:52 PM
How do I mount a Router to a table demaX Table-mounted Routing 3 04-16-2009 06:56 AM
