Tongue and groove cuts - Router Forums
post #1 of 5 (permalink) Old 03-13-2010, 05:32 AM Thread Starter
Default Tongue and groove cuts
Hi guys,
I am in need of some advice please....
I want to join to pieces of 2 inch timber togther on a 90 degree joint using tongue and groove method.
I just cannot seem to cut the joints......I am able to cut about 1 1/2 inches into the piece so that the cut does not show when I join the two together, problem is the end of the cut leave a slant where the cutting T&G blades had been stopped from cutting futher, I cannot seem to cut a smooth finish joining the pieces together.
Any advice please
rab4554 is offline
post #2 of 5 (permalink) Old 03-13-2010, 06:44 AM
Originally Posted by rab4554 View Post
Hi guys,
Any advice please
Hi rab - welcome to the forum
I guess I'm having trouble understanding what you are trying to do, a "STOPPED" tongue and groove?
John Schaben
jschaben is offline
post #3 of 5 (permalink) Old 03-13-2010, 11:10 AM
Hi,
I'm having trouble understanding exactly what you are doing. If you are doing a stopped tongue & groove as John mentioned are you talking about the radius of material left from the round bit? If so just use a chisel to square out your groove from the cutter.
A picture of your situation would help understand what you are trying to accomplish.
Whittier, CA.
Have a nice & safe day!
jlord is offline
post #4 of 5 (permalink) Old 03-13-2010, 12:01 PM
istracpsboss's Avatar
Country: Croatia
First Name: Peter
istracpsboss is offline
post #5 of 5 (permalink) Old 03-13-2010, 12:34 PM
Hi
I think I know what you are trying to do,,this a norm on the T & G joints on the shaker way of making cabinet doors, etc.
The T & G bits will do a good job and the joints will be on the blind inside of the frame, you will need to make your own set of the T & G bits, most don't go more than 3/4" wide stock the norm, I made my own arbors to do just that, they will do a 2 1/4" wide stock, but you will need to stack the cutters up..
Hi guys,
Any advice please
2x tongue and groove ? youngmj General Routing 4 02-04-2009 11:49 PM
homemade tongue and groove panels overthehill New Member Introductions 5 01-22-2009 11:56 PM
New to the forum - Advise PLEASE about Tongue and Groove Flooring Darby New Member Introductions 7 03-25-2007 04:07 PM
Spline vs. Tongue & groove wanart General Routing 1 02-28-2006 06:22 AM
Tongue and groove bits archer_456 General Routing 4 02-18-2005 05:51 AM
