Routing - Router Forums
post #1 of 2 (permalink) Old 03-17-2010, 06:25 PM Thread Starter
First Name: Pierre
Default Routing
How do rout a dado on a particle board cover with melamine without chipping the edges, is there a special bits for that purpose ?
Thanks , papapierre
papapierre is offline
post #2 of 2 (permalink) Old 03-17-2010, 06:47 PM
Hi
Check out the video below it will help
Brian Havens, Woodworker
If you want to use the router to do the job I would suggest the bit below..
Compression Up/Down Spiral Router Bit
http://www.mlcswoodworking.com/shops.../bt_solid.html
"This 2 flute solid carbide bit is needed to get clean, chip-free and splinter-free cuts in composite sheet goods such as Melamine or 2-sided Formica/Laminates and veneered plywood.
The Up-shear/Down-shear design of the bit cuts toward the center of the sheet from both sides at once, saving time and eliminating waste."
Thanks , papapierre
Routing Template Verlin Garrett Jigs and Fixtures 16 08-17-2019 09:12 PM
Forum Suggestion Thread Mark Site Help and Suggestions 131 02-08-2015 09:33 AM
New to Routing and already lost!!! sarahrodgers New Member Introductions 10 12-31-2012 11:30 PM
Routing + Template Confusion prav1988 General Routing 8 05-27-2009 08:54 AM
Router table or Plunge routing template tom Guide Bushings and Templates 15 04-14-2009 02:45 AM
