Bosch 1613EVS plunge router - Router Forums
 4Likes
post #1 of 18 (permalink) Old 03-23-2010, 08:34 AM Thread Starter
First Name: George
Default Bosch 1613EVS plunge router
My son has a Bosch 1613EVS Plunge router that we are using in a router table. After a short time in use the router "slips" down and ruins the project. Is there a way to increase the pressure on the plunge lock mechanism to prevent this problem??
Thank you.
egroeg1930 is offline
post #2 of 18 (permalink) Old 03-23-2010, 02:15 PM
DerekO's Avatar
First Name: Derek
Welcome to the forum.
I don't have the answer to your question, but have you cleaned everything out good? I find that some things can have saw dust creep up into places you never thought it would. I don't use a plunge router in a table so don't have much experience with that, but I have seen others mentioning removing the plunge springs before using a plunge router in a table. I don't know if that is just personal preference or only done when that is all the router is going to do or if that is the way it is supposed to be done.
I hope you can find the information you need in the various threads, or that some one who knows a lot more than me responds.
DerekO is offline
post #3 of 18 (permalink) Old 03-23-2010, 04:48 PM
xplorx4's Avatar
First Name: Jerry
Greetings George and welcome to the router forum. We are pleased you have chosen to join with us.
Lamentations 3:22-23
xplorx4 is offline
post #4 of 18 (permalink) Old 03-24-2010, 01:15 AM
Dr.Zook's Avatar
First Name: Dave or "Doc"
George, welcome to the RouterForums. Thanks for joining.
Dave
the "Doctor"
Dr.Zook is offline
post #5 of 18 (permalink) Old 03-29-2010, 08:10 AM Thread Starter
First Name: George
Thanks for the reply. I would have responed sooner but I was having a few computer problems. I'm not a high speed computer user(I'm a learner). I appreciate the information and I will look into the plunge mechanism. The 1613EVS doesn't come out of the mount like the 1617 that I have with two different bases. Bosch says a plunge router should not be used in a table. I was able to get the following information on the net that explained a "correction" for the slipping problem. We are going to try it and see if it works. The site was (sorry, it wont let me post site, not enuf "posts". I'll be back.
Thanks again to all- to DerekO, Dr. Zook and Explorx4
post #6 of 18 (permalink) Old 03-29-2010, 02:55 PM
Hello, I have an older 1613 that had the same problem. The slippage problem was caused by looseness in the microadjust system. I fixed it by tapping the toothed retaining washer, located under the fine adjustment knob, down on its shaft using a 1/2" deepwell socket and hammer. This tensions the wave spring trapped between two washers sitting below it. This spring is #62 on the ereplacement parts diagram (part number 3604680502). I hope this helps.
RTR likes this.
Mikemorgan is offline
post #7 of 18 (permalink) Old 03-30-2010, 12:21 AM
Dr.Zook's Avatar
Hello Mike, and welcome to the RouterForums community of woodworkers.
Dave
the "Doctor"
Dr.Zook is offline
post #8 of 18 (permalink) Old 03-31-2010, 04:29 PM Thread Starter
First Name: George
Thank you Mike, we'll give that a try also. Woodworking would not be fun if everything worked out great.
George
post #9 of 18 (permalink) Old 04-17-2011, 10:37 PM
George,
I recently had the same issue with my Bosch B1450 (I believe is extremely similar to the 1613 EVS). The weight of the router itself as well as the spring pressure would allow it to drop slightly during use.
My solution was simple:
- With router fully plunged and locked I took the screw out for the yellow plunge lock lever.
- I removed the lever being careful not to lose the small washer, screw and spring to expose the locking screw.
NOTE--> The locking screw is a left-handed screw; to tighten turn 1/4 turn CCW (vice CW for tightening of standard right-handed screws).
- Then I put about an extra 1/8-1/4 turn on the locking screw.
- Then I reinstalled the lever. I can still use it like normal, but now I have a little extra travel to really tighten it down when installed in the router table. It is still possible to slip under heavy use, especially with hardwoods, but with easy feed and sharp tooling I have not noticed any issues.
- If you try this and it still slips try tightening a little more. That is if everything else mentioned above checks out and is in good working order. (fine adjustment not loose/slipping and router is not loaded up with saw dust.) If the router's home will be installed to the table then pulling the springs out is not a bad idea.
Hope this helps.
AJ
PS: Router table being used is Bosch RA1171 Benchtop Table. Using the 1613 mounting holes.
RTR likes this.
AJBinVA is offline
post #10 of 18 (permalink) Old 09-29-2012, 07:56 PM
Had the same problem with the same model router in a table. In my case, I took the plunge lock lever off its shaft and rotated it a little counterclockwise, then put it back on.that gave it more room to travel clockwise to really clamp down and lock the plunge mechanism.
Good Luck!
RTR likes this.
Leftwrite is offline
No Lift Systems To Fit Bosch 1619EVS 3.25HP Router? DennisP General Routing 4 01-20-2010 05:23 PM
Fixed Base or Plunge Router tdsapp General Routing 11 06-13-2009 02:55 PM
Sears Plunge Router Model 315.275110 Wally99 Table-mounted Routing 3 12-24-2008 06:39 AM
My New Bosch Router Bosch 1617EVSPK Review GoonMan General Routing 2 04-02-2005 05:25 PM
