Replicating Old Doors - Router Forums
post #1 of 4 (permalink) Old 03-24-2010, 05:53 PM Thread Starter
First Name: George
Default Replicating Old Doors
Hello. I am trying to replicate the panel mould on these old doors and was wondering if I will have to make a custom piece of molding for the curved top and bottom portion or it this is something that can be purchased online or at a local store? Here is a picture
If this is something I would need to make, what is the best way to do it?
Thanks in advance.
SATX78209 is offline
post #2 of 4 (permalink) Old 03-25-2010, 01:31 AM
Dr.Zook's Avatar
First Name: Dave or "Doc"
SATX, welcome to the RouterForums. Glad you signed up.
Dave
the "Doctor"
Dr.Zook is offline
post #3 of 4 (permalink) Old 03-26-2010, 10:26 AM Thread Starter
First Name: George
Thanks, Doc. I look forward to learning from you guys.
Someone recommended that I use a flexible piece of trim. Does anyone have any thoughts on this? I would guess that it might be better to build some sort of jig so that I can have the exact same curve on the top and bottom of all four doors. However, I've never built a jig before so I really don't know how I would go about doing it. Any thoughts?
post #4 of 4 (permalink) Old 03-26-2010, 10:44 AM
Hi George
I would suggest using the Cathedral type Templates, use it to put down the shape and use a profile bit to put the molding on the stock and than the band saw to remove the molding from the stock..little bit of sanding and you have it.
Templates-Cathedral
Templates-Cathedral-Sommerfeld's Tools For Wood
Bathroom cupboard doors locoboy Show N' Tell 6 01-19-2012 11:47 AM
What size Router for making raised panel doors? TRN_Diesel General Routing 16 04-17-2010 05:37 AM
French Doors & Mullions - Router Bit? FrenchDoor Router Bits - Types and Usage 20 10-09-2009 09:04 AM
We produce 400 passage doors per month. Thoughts on using CNC machine? Rmarsh CNC Routing 5 02-22-2008 09:21 AM
