Router Speed Control Mounting - Router Forums
post #1 of 14 (permalink) Old 03-28-2010, 01:09 AM Thread Starter
BigJimAK's Avatar
Default Router Speed Control Mounting
Is anyone aware of router speed controls that comes with a bracket for mounting it to (or better yet into) a router table? The ones I've seen appear designed to rest on the table, for handheld routing. It seems like it'd be a real disadvantage to be limited.
The router would be single speed and not a soft-start model.
BigJimAK is offline
post #2 of 14 (permalink) Old 03-28-2010, 07:37 AM
rick7938's Avatar
I have been trying to accomplish the same thing for months with little luck. I guess the next course of action is to take it apart and drive screws through the metal back. There should be an easier way. I look forward to other suggestions.
rick7938 is offline
post #3 of 14 (permalink) Old 03-28-2010, 07:56 AM
Cochese's Avatar
First Name: C
Two ideas:
1) buy one like the MLCS 9410 and mount it via a magnet. It's just a circuit board inside, so it shouldn't hurt it.
2) bend some metal and make a cradle
Cochese is offline
post #4 of 14 (permalink) Old 03-28-2010, 08:07 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
Come on Jim, since when has mounting anything been a problem for YOU? This sounds more like a rhetorical question coming from you.
Harry
harrysin is offline
post #5 of 14 (permalink) Old 03-28-2010, 08:19 AM
Hi Jim
The Speed control below comes with a bracket ( holes) just for that job.
It's has two slot holes on the back side of the control box , like many of the outlet bars have..just slip it on the screw heads and push and snap it in place.
- Harbor Freight Tools - Quality Tools at the Lowest Prices
http://www.mlcswoodworking.com/shops...d_control.html
post #6 of 14 (permalink) Old 03-28-2010, 08:54 AM
TwoSkies57's Avatar
Jim...
just gut one out....contain the exposed side so sparkage isn't an issue...I dont' know that it would be,,, but better safe than sorry
TwoSkies57 is offline
post #7 of 14 (permalink) Old 03-28-2010, 09:22 AM
Cassandra's Avatar
First Name: Cassandra
Jim:
Just looking at the picture of the MLCS heavy duty speed controller, I suspect it would be easy to mount on a surface.
Possible mounting techniques:
1. Does the controller come with mounting hardware?
2. Does the controller have key-hole mounting holes on the back of the aluminum case?
3. One could use a pair of wide Z-clips (one on top edge and one on bottom edge.)
4. Remove aluminum case back, mount it with screws, and then re-install the electronics.
Just some suggestions,
Cassandra
Carpe diem, quam minimum credula postero
http://www.panoramio.com/user/5924351
Cassandra is offline
post #8 of 14 (permalink) Old 03-28-2010, 01:45 PM
Hi Cassandra
1.= No
2.= Yes
3.=no need
4.= rivets to keep the end user out of the box and playing with the electronics.
Originally Posted by Cassandra View Post
Jim:
Cassandra
post #9 of 14 (permalink) Old 03-28-2010, 02:05 PM Thread Starter
BigJimAK's Avatar
These are some *great* ideas... and thanks for the insight, BJ.. I notice you mention mounting on the back. The basis for my question is... speed controls are notorious for generating heat... which kills electronics unless dissipated... so one designed for "perimeter mounting" would need to be designed to dissipate its heat through the front and back while those with apparent heat sinks seem to have them around the perimeter, where air would not flow if panel-mounted.
It sounds like the best alternatives so far would be either to follow BJ's suggestion and/or start buying and disassembling the SC's to ensure their heat sinks are able to do their job. If one had its heat sink inside the box, removing the box and replacing it with my own vented box (since it'll be out of reach for fingers) might be an option too.
BJ.. Is it the heavy-duty one that has the slot holes, that you are aware of?
I guess I could also likely remove the speed control pot from the case and mount it through the face, with the rest of the electronics still in the box and inside the cabinet. Any flaw in my logic, assuming the pot isn't soldered into a printed circuit board?
BigJimAK is offline
post #10 of 14 (permalink) Old 03-28-2010, 02:07 PM Thread Starter
BigJimAK's Avatar
Hi Cassandra
1.= No
2.= Yes
3.=no need
lol, BJ... Reee-veets? Reee-veets? We don't need no steeenking reee-veets. Isn't that what drills are made for? <g>
BigJimAK is offline
Hello DPugmire New Member Introductions 5 11-08-2010 06:29 AM
Router speed Allejo General Routing 6 10-17-2009 06:54 AM
Router Speed Guide CanuckGal Starting Off 9 12-25-2008 04:52 PM
Mounting a router to a table mounting plate rberry Starting Off 8 06-14-2008 10:24 PM
Router speed controls RustyW Starting Off 1 12-29-2005 06:42 AM
