Some interesting inlay work... - Router Forums
post #1 of 17 (permalink) Old 04-02-2010, 04:50 PM Thread Starter
Hamlin's Avatar
First Name: Ken
Default Some interesting inlay work...
Here's another link from Youtube. This is a 45+min vid. Kinda interesting and yet makes me cringe at some of the method being shown.
http://www.youtube.com/watch_videos?...&no_autoplay=1
Ooops, thanks Harry.
Ken
"A VETERAN"
Last edited by Hamlin; 04-03-2010 at 06:31 PM. Reason: added the forgotten link :D
Hamlin is offline
post #2 of 17 (permalink) Old 04-03-2010, 09:29 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
It's good to see you back Ken, however, the time away seems to have made you forget to post the promised link! I hope you're having a very pleasant Easter.
Harry
harrysin is offline
post #3 of 17 (permalink) Old 04-03-2010, 06:32 PM Thread Starter
Hamlin's Avatar
First Name: Ken
Thanks Harry , I added the "forgotten link".
Ken
"A VETERAN"
Hamlin is offline
post #4 of 17 (permalink) Old 04-03-2010, 07:41 PM
Hi Ken
THANKS,,That's a great how to link, I like that part about the sand,that's a new one for me ..
I use the scroll saw for all the work,that way I know for sure all the parts will fit.
I wish I had that much control over the router like he has. so to say I have a inlay on both sides of the board so to speak...
1/16" router bit
Amazon.com: Freud 04-096 1/16-Inch Diameter by 1/4-Inch Double Flute Straight Router Bit with 1/4-Inch Shank: Home Improvement
Amazon.com: Magnate 1956 Straight Router Bits - 1/16" Cutting Diameter; 1/4" Cutting Length; 1/4" Shank Diameter: Home Improvement
post #5 of 17 (permalink) Old 04-03-2010, 08:48 PM Thread Starter
Hamlin's Avatar
First Name: Ken
Hi Bj,
You're welcome my friend. Did you notice how he held the router? I'm wondering if "ski's" wouldn't have worked better.
Ken
"A VETERAN"
Hamlin is offline
post #6 of 17 (permalink) Old 04-03-2010, 09:35 PM
Hi Ken
yep, I did see that,I have tried that b/4 but with a light router I may try it his way with a tank of a router, that made a lot of sense I don't think the ski jig would help on that type of job...
Just one more inlay video ▼
http://brianhavens.us/resource/router-inlay-basics
http://www.rockler.com/product.cfm?p...&filter=inlays
Hi Bj,
post #7 of 17 (permalink) Old 04-04-2010, 08:43 AM
First Name: Dominik
tigerhellmaker is offline
post #8 of 17 (permalink) Old 04-05-2010, 11:37 AM
rwyoung's Avatar
First Name: Rob
Marc does bring up some good points on finding your own degree of comfort. With a large router (the Festool being on the small end of the large router scale) it should be reasonably safe to hold low. But you are putting your hands in the path of a snapped bit. Skis or a larger sub-base with peg handles might be better. For me, my ski jig worked great for some carving. This was because I was relieving so much of the background, the router base would not be fully supported otherwise.
And Harry had some good posts in the ski threads about mounting worklights and a magnifier on the skis. That would be a good idea here, you could have a pair of safety glasses on and still get the magnification right at the bit.
When I last did some carving with my router I was OK without the magnification but because I was putting my face right down there I decided to go with the glasses plus face-guard just in case a chip flew out. I didn't want a small chip hitting my cheek and making me flinch. The only thing missing was rigging a hose up on my skis to do some vacuuming of chips. Instead I stopped frequently to dust them out.
As to the small bits, I got some great ones from Think and Tinker (precisebits.com). Sold as "2 flute fish-tail end mills". They are 1/8" shank but you have the choice of letting T&T press on a 1/4" collet adapter, using a 1/8" adapter in your chuck or for some routers they will sell you a 1/8" collet. I went with the 1/4" adapters pressed onto the bit shafts. Worked great. $10 for a 1/32" plus $3 for the bushing.
An alternative method is to stake in along the cut line with the appropriate gouges (bevel into the waste area), then chisel out the waste. Chisel out to about 3/4 or more of the finish depth, don't sweat that it isn't level. Then use a small router plane like the Stanley #271 or a larger plane (#71 or #71-1/2) if you need more support area and a small pointed blade. You can also make an "old woman's tooth" plane for this job and the blade from a hex-key. But unless you heat-treat the blade, it will require frequent sharpening. Use the router plane to level the area and the pointed blade gets you into all but the smallest corners. Those still have to be done with small chisels, picks or the X-Acto blade. Slower but no flying chips to freak out the safety patrol.
rwyoung is offline
post #9 of 17 (permalink) Old 04-05-2010, 11:16 PM
harrysin's Avatar
First Name: Harry
Hi Ken
1/16" router bit
Do you understand now Bob why I use a BIG router, so much easier to control.
Harry
harrysin is offline
post #10 of 17 (permalink) Old 04-05-2010, 11:25 PM
harrysin's Avatar
First Name: Harry
Thanks for that link Ken. Marc really is a great presenter, he knows what he's doing and his uninterrupted commentary is so easy on the ear.
One of these days I'm going to give it a go rather than my usual method of pre-made inlays. I will however use the skis, which are the perfect answer for this operation.
Harry
harrysin is offline
Quick fix for router work. jigman Portable Routing 12 02-22-2010 04:55 PM
Sigh... all that work for nothing... tdsapp Table-mounted Routing 34 12-31-2009 04:15 PM
inlay bushings gumball Guide Bushings and Templates 4 10-29-2009 01:40 AM
New work bench/drill press opelblues Show N' Tell 7 09-30-2009 09:19 PM
